Which ABC hose is this
Noticed it leaking this morning. How hard is it to change, please tell me this isn't the one were I have to lift the engine. The circle at the top is were its spraying out
Can you confirm that the leaking pipe comes out of the BOTTOM of teh forward valve block and bends round to run horizontally backwards?
If so its probably the pressure feed into the valve block - I'll get some more details.
The pipe that runs under the engine is connected to the pump, not the valve block.
Nick
Nick
I just checked my car - its definitely the supply/pressure/feed hose into the valve block.
In the picture, the pipe in front goes to the thermostat.
It looks easy to replace.
Nick
Nick
Still trying to figure out which hose it is , called. I started a new thread documenting the process of changing it out. Should be fun. Any help you could give would be appreciated
