CL-Class (W215) 2000-2006: CL 500, CL 600
ABC Pump
Old 12-07-2014, 04:34 PM
cccrtdvss's Avatar
2004 cl500
ABC Pump
May have burned up my pump, short story i removed both front struts so i could replace both upper control arms when i reinstalled the struts i did not have the line all the way on and when i started the car almost all of my fluid leaked out before i notice the leak i shut the car off checked the dipstick and there was about a inch and a half of fluid on it so i dont think it went completely dry , so i topped it off but now when i start the car it wont do anything and after about 10 seconds of running the red abc message comes on can some tell me how and where to check the pressure or lack of any help would be greatly appreciated.
Old 12-08-2014, 01:46 PM
Welwynnick's Avatar
2006 S600
Pump is probably OK.
Just need to bleed it properly, which is difficult. You can't just fill the reservoir. That would be too easy.
1. Pressurize the ABC reservoir with a few PSI of air, to force the oil into the pump.
2. Alternatively, remove the aux belt and spin the ABC pump pulley with your hand until it firms up.
Nick
Old 12-08-2014, 02:02 PM
cccrtdvss's Avatar
2004 cl500
Thanks for the info, forced air into the tank with car running pump primed up and the car went up, shut it off check the fluid add some to top it of, went up and down about 15 times check fluid again, bled it at all 4 corners so far so good will see how it goes, thanks again for the info
Old 12-08-2014, 05:06 PM
Welwynnick's Avatar
2006 S600
In fifteen minutes?!?!
Anyhow, good result.
Nick
Old 12-08-2014, 06:19 PM
cccrtdvss's Avatar
2004 cl500
I did a search this morning that said the same thing you said to do, but am still very thankful that you took the time to try and help a fellow member out took me about 3 hours.
Quick Reply: ABC Pump
