CL-Class (W215) 2000-2006: CL 500, CL 600
PSE Lettering
Old 07-05-2015, 12:41 PM
Lestere's Avatar
CL55 AMG, Pontiac Bonneville SSEI
PSE Lettering
I'm trying to get a handle on a vacuum leak on my 2002 CL55 AMG. I don't understand what parts these letters refer to and I could sure use some help. I disconnected and reconnected each pipe after doing a vacuum test and my results are as follows:
MKC Rises but drops fast
FT Holds good
BFT Zero no vacuum
TD Rises but falls slowly
HECK Rises but falls slowly
KAF Rises but falls slowly
SK Zero no vacuum
My drivers door lock wont open or close, but I do feel that there is vacuum there because it closes on it's own and it is sometimes hard to open the door by the lever, and then it closes immediately afterwards on it's own. The roof won't open, and the lumbar in the seats won't work at all.
So I really need to know where these lines are going to
Thanks.
Old 07-05-2015, 01:38 PM
ItalianJoe1's Avatar
2003 CL 600
Where did you get that test result from?
Old 07-05-2015, 05:08 PM
Lestere's Avatar
I connected to each hose individually and I used a hand pump vacuum with a gauge to pump vacuum from each pipe.
Old 07-06-2015, 06:58 PM
Lestere's Avatar
Help with PSE pump lettering on a 2002 CL55 AMG
I really need to know where the pipes go that are connected to these:
MKC, FT, BFT, TD, HECK, KAF.
i found some other markings on a PSE pump on this site but they don't match mine.
Thanks in advance.
Old 07-07-2015, 09:00 PM
Super Moderator
awiner's Avatar
2003 CL55 AMG
BFT - Front Right Door
FoR - Right Rear Door (if equipped)
FT - Front Left Door
FoL - Rear Left Door (if equipped)
TD - Fuel Door
HECK - Boot Lid
KAF - Rear Head Restraints
MKC or SK - May be Central Locking
Old 07-08-2015, 12:51 PM
Lestere's Avatar
PSE Lettering
Thanks very much awiner for all of your very valuable help.
Its really strange that the right door is opening and closing fine with the remote(BFT) but shows zero vacuum on the gauge, while the left drivers door (FT) doesn't work at all but holds a good vacuum. Canada left side is drivers side as far as I know
Old 07-08-2015, 09:40 PM
calgary's Avatar
2001 Mercedes CL500 2006 E350 4-matic
Yes, Canada is left side drivers side....I believe FT stands for Fahrer Tuer (Drivers Door) BFT - BeifahrerTuer (Passenger Door) Just guessing...
Quick Reply: PSE Lettering
