CL-Class (W215) 2000-2006: CL 500, CL 600
2001 CL600 Blower Motor Not Working
Old 01-06-2016, 05:49 PM
AtlanteanTitan's Avatar
CL600
Hello, the blower motor always made a high pitch sound running at low speeds, increasing the speed over 2 bars use to cut the noise, and very seldom the motor stopped working although turning it off and on again used to fix that issue. Lately, when I put it on high speed it stopped working and again turning it off and on again fixed it but is not a fix anymore, the blower motor has stopped working completely. I did check the fuses (f33) but that seems not to be the issue. I would like to change the blower motor and check to see if the resistor is blown as well. Would anyone know where they are located, I tried to take the cover below the glove compartment out but removing the screws did not even loosen it, maybe there is trick to it. Since I'm not sure, I don't want to take things apart unnecessarily. Your help is appreciated very much since without the motor running, inside the car will be very cold here in NY. Thanks for all your help...
Old 01-07-2016, 11:04 AM
slonar21's Avatar
CL600 2003
Look at this post, at the bottom
http://www.benzworld.org/forums/c215...mell-then.html
Try using google to search, It took me 5 seconds typing "replace blower w215"
Old 01-07-2016, 12:29 PM
CL600
Thank you slonar21 for your link, this will help me fix it. I did search on google, I guess cl500 and 600 are pretty much the same repair wise.
Old 01-09-2016, 10:47 AM
CL600
Directions For Replacing 2001 CL600 (W215) Heater Blower and regulator
Here is the diagram for replacing the heater blower fan and the regulator.
Quick Reply: 2001 CL600 Blower Motor Not Working
