Renntech Hand Held Tuner CL600 review
Hi
Thought i'd write this for anyone who is considering buying the Renntech Remap/Handheld Tuner for the CL600 Bi-Turbo.
One word..amazing!
I decided to get the handheld tuner as you can go back to a standard tune as and when required with a flick of a switch which living in the UK can be useful as when it rains 625bhp has no use!
I have been running the map now for about 6months with no issues, only tyre and brake wear. Before though i did fit new coil packs,spark plugs as one coil pack was faulty, new Ignition control unit to be on the safe side and changed all fluids and uprated Bosch charge cooler pump.
There are from what i have seen other maps which are cheaper and some give more power but stuck with Renntech due to their reputation.
Its a very odd sensation as no matter what speed you drive at, it pulls the same wether 0-60mph or 60-150+ just ridiculous!
Only draw back i have found is when driving slow around towns/cities you feel like your "riding" the brakes more than usual as its always wanting to go if that makes sense. But then if you do drive around town, you can always go back to the standard tune. Once plugged in the map takes about 2-3mins to upload the file.
Hope that helps as i always think its good to give something back to the community, and as always keep it sideways!
One word..amazing!
Interesting, thank you for sharing. I just got an ECU and TCU tune from Kleemann and am enjoying it so far. My review is to come. I did not do all of your prep, I kind of just threw it on there. For me, the car drives very similar to how it did before, unless I put my boot in it. Has the upgraded pump shown any benefit?
I was looking at the Kleeman one too i just like the idea of having standard and tuned. Yeah i only did prep work as one of the coil packs was broke anyway so thought, do the rest whilst i'm at it. Has the TCU upgrade any difference? I can get that as an extra upgrade too but quite happy with the gearbox as it is for now.
Only difference i've found is it pulls strong right up to the red line where as before with the old pump (which was dead) just didnt feel to pull as strong like the power tethered off. I think though the pump some recommend the Johnson one but i just like the plug and play of the Bosch.
03 CL600
Hmm good review. Im most likely going to get the renntech HHT for my cl600 because it is much more convenient for me to just plug and play vs removing the ECU and shipping it. I also like the fact that you can switch off the tune as you feel. Thanks for the review.
Received 1,003 Likes
E55, GLS450, GL63, GLE350
When I had my CL600, I shipped the ECU and TCU off to Renntech. The handheld tuner was not an option. On mine, I gained 125 rwhp with just the tune. Totally transformed the car.
Only draw back i have found is when driving slow around towns/cities you feel like your "riding" the brakes more than usual as its always wanting to go if that makes sense. But then if you do drive around town, you can always go back to the standard tune. Once .......
One thing I'm very aware of in my Eurocharged tuned car is that it DOESN'T creep like other automatics do, especially in reverse, and it needs a surprising amount of revs to pull away slowly.
Its like the torque convertor is slipping, or there's a brake being applied within the transmission.
I didn't think a tune would affect this sort of thing, but maybe yours does?
Cheers, Nick
Are you sure your car isn't starting off in second, Nick? I know mine does in comfort mode, but in sport it takes off like a normal car. In reverse, it does take more effort than most cars, but not overly so. I've noted no tendency to have to ride the brakes, but I did also have the TCU tuned as well.
Mercedes do not have the same idle creep that other cars do. Volvo also don't have it
Regardless of that I always Leave mine in sport it feels sluggish in C
On some years it was called S and W for winter mode as it would start the transmission in second
That's interesting. Is the idle speed any higher?
Cheers, Nick
Cheers, Nick
Idle speed is the same, just seems to have more low down grunt. Even with standard exhaust too it sounds more throaty at idle when on the tune, unless its just in my head? Either way good fun!
