CODE OUT ABC
CODE OUT ABC
Hi
I am on my coil over suspension conversion
I have all things listed from ajusteble spring to sway bars
i'll post a topic when avanced
now my last issue to solve is the ABC warnings
now, strutmaster's module is
but I doubt that if I remove all ABC parts except the pump that this module we handle warnings.... strutmasters on the phone pretend it replaces the whole abc module stuff......
on the other side, as I have STAR DAS and developper mode
i thought it would be possible to code out ABC...
and I read here:
http://www.rebuildmastertech.com/mer...onversion-kit/
"15 Hours of labor and reprogramming the ABC out of the system so no warning lights come on. We can work to assist your mechanic with the installation."
so coding out ABC is possible ?
some super user and moderator here say so... but HOW HOW HOW how how (Austrian mountain's echo)
https://mbworld.org/forums/cl-class-...ion-lamps.html
if you say something like that say how please, or shut your pie*****
(I am not aggressive so don't badly comment this. we are here to find solutions, not to create rumors.....)
and I read here:
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
Okay so I'm gonna chime in like I always do for these coilover threads when comparing CL/S and SL. SL can be coded out because on the R230 they offered coilovers on the SL350 and SL65 BS. You cant do CL or S via SDS cause mercedes never offered the car with coilovers. But yes on a SL it can be coded out 100% because I did it on my SL65 and even put a walkthrough how to do it on the R230 AMG thread.
pmercury (12-27-2016)
If you had an R230 this is how you would do it
https://mbworld.org/forums/sl55-amg-...r230-cars.html
I asked RMT about CL/S and coding it out if I wanted to buy a CL65 and do the yellowspeed coilovers and they said cant be done on SDS and you need some kind of module to trick the system.
Im curious if that Strutmaster can box works alot better on cars coded at airmatic? Isnt the box the same for there S class airmatic kits?
well, a thing I read somewhere is that if I switch to airmatic, I would only have 1 white message on every startup that I can remove with the R button
also, and this is why I do some upfront research, I called strutmasters and they said the box replaces the whole ABC module in terms of signals faking all of it.
If that is so, then it's a fabulous device. but I have a doubt
I think it only fakes the 4 sensors on the top of the abc struts or maybe those and the height/level sensors
that would mean that you have to have a perfectly working ABC system with pressure ect
which is ridiculous of course
but lets see.. one step by one
http://www.strutmasters.com/products...s-module-ma1m/
Fits:
- 2000-2006 Mercedes S-Class (ALL including 4-MATIC)
- 2000-2006 Mercedes CL-Class
- 2003-2006 CLS-Class
- 2003-2009 Mercedes E-Class (including wagons and 4-MATIC vehicles)
- 2007-2012 Mercedes GL-Class
Just recalling you guys that the threat is going on also over here
https://mbworld.org/forums/sl55-amg-...230-cars.html?
BUT PLEASE, ONLY POST HERE or the project is going to be confusing
doesn't looks like that but:
Fits:
Fits:
