using star diagnostic to disable abc warnings/other indication lamps
the only thing is since i removed both fuses for the abc to get rid of my error, my cigarette lighter doesnt provide power. maybe its unrelated
no sway bars, i would like to find a way to make some strut tower braces as it seems you could just un screw the top strut bolt on each side and place a bar inbetween the two just fine if it was cut the right length and had the correct holes for the tops of the struts. the car handles fine without them as the spring rate is somewhat stiff (about the same stiffness as the abc system but more forgiving on small bumps) but im sure the handling would be improved in heavy cornering/high speed lane changing with a sway bar set up. same thing with the rear but the particular piece would have to be fabricated in a way to not interfere with rear window
edit:oh, i just realized you were replying to somebody else
I home someone tries and succeeds but I have a doubt about white and red warning lights
It might work if you code out ABC with Xenty, you have that options in ME-SFI 2.7.1 engine module line 0217
let us know
I have no time for that right now
