CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
my cl 55 is stucked in limp mode, how to reset?
Old 04-12-2014, 05:29 PM
stephaneadam74's Avatar
cl55 2003 amg
how to reset the tranny
Old 04-12-2014, 10:42 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
it may be not be possible without DAS
You can try to disconnect the TCU for a minute and then connect it, it may solve the problem
Old 04-14-2014, 10:15 AM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
For battery reset,,, turn the key to on position and then disconnect the battery for about 5 -10 minutes, then turn key off, then re-connect battery. You will then have to reset all your windows, sun roof and steering.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Quick Reply: my cl 55 is stucked in limp mode, how to reset?
