HELP - 2005 CL65 Drivers Side and Rear Window Not Sealing Fully Upon Shut-Off
Got in the car today and slammed the door ... usually I just pull the door close and it is then automatically pulled shut and windows seal up and against each other. When I went to get out, I pulled on the handle, the windows did their customary slight drop and pull apart and I got out. But when I gently closed the door, the windows did not move back into place leaving a slight opening at the top of the window.
I checked and the passenger side and rear side windows work normal.
I am fairly certain I am not the first to find this problem - anyone else experience this and if so, what did you do.
Thanks in advance.
Chris
Thanks in advance.
Chris
Speedriven CL600 V12TT
If it's not normalizing the windows, then you have a far worse problem on your hands. Roll your window all the way down, then hold it for 5 seconds or so until you hear a faint click. Do the same thing when rolling it back up. Hopefully that should fix it.
If this doesn't fix it then it may be the Door Control Module.
