1998-1999 CLK 320 Oxygen Sensor Info
1998 CLK 320
Just wanted to pass along some info I found for O2 sensor replacement.
Bank 1 (Right) Passenger Side
Bank 2 (Left) Driver Side
Right Upstream Bosch OE Exact Fit #15090
Left Upstream Bosch OE Exact Fit #15088
Right Downstream Bosch OE Exact Fit #15092
Left Downstream Bosch OE Exact Fit #15094
Hope this helps!
Hope this helps!
1998 CLK 320
Oxygen Sensor Info
Yes, All are the same fit except for the Left Downstream Sensor depending on your car's production date. Production Date Thru 5/2000 Bosch 15094.Production Date From 6/2000 Bosch 13580.
1999 CLK 320
Does anybody know the exact location of the 02 sensor bank 1 position one? I have the following code (P0130 O2 Sensor Circuit Malfunction Bank 1 Sensor 1) and would like to know which part to buy. Thanks
1998 CLK 320
O2 Sensor P0130 Code
Bank 1 Sensor 1 is passenger side upstream of the Primary Cat.(Close to the exhaust manifold) Bosch #15090. Bank 1 Sensor 2 would be downstream of the Primary Cat.
Mercedese CLK 320 1999
Check engine light is ON, for following codes
P0156 (O2 Circuit Bank 2, Sensor 2)
P0141 (O2 Heater Circuit Bank 1, Sensor 2)
P0161 (O2 Heater Circuit Bank 2, Sensor 2)
Can any one help and tell me which O2 sensors i need to replace
and where to by them cheap
thanks
thanks
