Noise like a chain dragging
I only just noticed this when finally able to drive with the top down on my 2003 W208 cab. A second or so before each upshift, the is a noise like a chain dragging on the ground coming from underneath the car. Once in top gear, no more noise. The car still shifts smoothly and at the right time, and you can't hear this with the top up, so it isn't really loud. Any ideas what this could be? It definitely isn't pinging from the engine.
It sounds alot like the same noise im experiencing but hopefully others will chime in. Mine is very noticeable with the top down and I can even hear it over my straight pipe exhuast, although it does no harm. If its shifting and running fine with the noise I wouldnt worry too much.
Have you ever heard the noise while you are not moving but in drive? Like at a stop light or ordering at a fast food drive through?
Have you visually inspected underneath the car for anything out of place? Inspected your shifter linkage bushing?
2002 CLK 55 AMG cabriolet Eurocharged
Possibilities are the driveshaft center carrier bearing support.
Driveshaft coupling, Transmission or Engine mount.
Exhaust hangers.
When a drive shaft flex disk (coupling) breaks away it can total the car.
Gator
Exhaust hangers.
Gator
Check under the car, flex disc, mounts, etc. bang on the cats a little with a rubber mallet to see if they rattle. If it's the rear cats, then just cut them out and move on unless you have stringent emissions testing where you live.
