Wheel help 17' to 19' swap
2001 CLK430 coupe
Here's a link that will help you compare wheel specs on the two vehicles.
Width may be a problem as well as tire OD. Tirerack is a good source for tire OD. The CLK has a 25" OD, I suspect the E class may be larger.
Good luck.
http://www.wheel-size.com/size/mercedes/
Good luck.
