A/C CLK430 2002
Old 07-27-2015, 03:57 AM
exhaustgases's Avatar
LS400
A/C CLK430 2002
No bad codes and refrig pressures are okay, pump works.
I think it is the flapper valve or what ever that directs the hot or cold air.
How hard is it to get at? When running the diagnostic I think all worked good. Are there servos that operate the valve? If bad they should throw a code?
Old 07-27-2015, 08:39 AM
Yidney's Avatar
2008 CLK550 Cab
A bad servo will not throw a code you can read, but MB's SDS can read them.
Old 08-17-2015, 03:58 AM
Scott Simoncic's Avatar
2001 CLK55 AMG
Grab the low pressure line while running, is it cold? What is your low pressure while running?
Quick Reply: A/C CLK430 2002
