ESP Error See Shop
Old 09-29-2015, 11:55 PM
ratanshah's Avatar
1995, E320 Cabriolet, 2002 CLK 320 Cabriolet
ESP Error See Shop
My CLK 320 Displayed above message and the car was then paralyzed. I could not shift gear without using mechanical release.
I ask about replacement $2000k thru the dealer. I was able to get a module from Ebay site with module being tested. Once arrived i am told it does not take car information. I have triple checked the module part # and reputation of Ebay seller.
I am unsure if our local dealership can not do it even if it were a new unit since it is likely this has not been dealt with in the past on a 2002 CLK 320 Cabriolet.
I do not want to put too much money in the car since it is old and with over 112000 miles.
Any thoughts or option ideas?
ratan 412 610 0429
Old 10-03-2015, 02:20 PM
Chadzu's Avatar
2001 Clk55 AMG
When the brake light switch fails it will cause this issue. Part is fairly inexpensive and is an easy repair.
Old 10-04-2015, 11:39 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
Did you try the brake switch? Like Chadzu mentioned cheap part ($10 - $20) known to fail and paralyze your car.
https://mbworld.org/forums/clk-class...ng-lights.html
Quick Reply: ESP Error See Shop
