Need Good Rain Tires for CLK.. recommendations?
I have the stock 430 AMG 17” rim on my CLK
I need to buy new tires.. and it’s starting to rain a lot here in the Bay Area, Ca. What tires do you guys recommend? Thanks
eso
eso
I have Michelin Pilot Sports on my CLK430, and they are <b>excellent</b> in the rain (I live in South Florida and see my share of the wet).
I hear good things from my friends about Bridgestone S-02s and S-03s, although I have never personally used either. The S-02s are discontinued, so you may have a hard time finding them.
If tread wear is an issue, I think the Michelin's may have a slight edge, but I'm not sure about that. They both cost about the same, but you may be able to find a good deal if you look around.
MBWorld Founder
Michelin Sports <b>are</b> excellent rain tires; even better than the new Bridgestone S03. However, the S03 is an awesome dry tire.
I'm still on my first set of Pilot Sports. I had to replace the OEM Pilot SXs at 12000 miles, and Sports are supposed to wear quicker than SXs. I expect the Sports to wear to about 10K miles, although I've had them for about 6k and they still look good to me.
I drive hard, but I've raised my tire pressure to 36 to compensate for the treadwear. The fronts go first because of cornering, I have 10,000 miles on my fronts, and probably another 1,000 miles of tread.
