Rear tail light upgrade (pre face lift)
w209 240 clk
Hi guys, im considering upgrading my prefacelift rear tail lights for the updated lenses, are these a straight swap as ive rear they are not? and the updated taillights need a slight modification to fit
cheers
2003 clk
cheers
2003 clk
04 CLK 320 > CLK32K
Yes the housing fits but you will need to bend a bit of the car to get the socket panel locked in. I used a pair of pliers. The whole install took me about 30 min just because I had previously taken out the lining and never put the clips back
04 CLK 320 > CLK32K
Well that socket panel on the updated tails is a different shape. You just have to bend a piece of the inner part of the car to get them to fit. Your basically just making the hole wider. Your old lights shouldn't have a problem being put back in. I will be doing some work in my trunk tomorrow if you like I will take some pics. It's pretty straight forward
I changed mine last year and it's been giving me error messages on the dash, saying something about replacement light ... anyone know how to fix this issue? Thanks
04 CLK 320 > CLK32K
I had that error with my old lights. I tried to change a couple bulbs to LED. Only one worked so I left it in. After a while I started to get the same error. Once I switched the bulb back it went away
04 CLK 320 > CLK32K
Try and swap out the bulbs on the side that's giving the error
I tired to make sure it would still line up with the foam seal on the light housing. Keep the outside elements out
W211 E55 - W209 CLK (gone)
Mercedes CLK 320 W209
Mercedes W209 Grille
Is it an AMG version? I have never seen that before?
Where did you get it?
Regards,
Mikael
thats a stock w209 grill on my car, u should get the starless one.
they're starting a groupbuy: https://mbworld.org/forums/group-pur...r-pricing.html
On your picture the grill looks like the one sitting on the new C class.
Have a nice day!
Rear lights
I just got my AMG lights today and they are not as dark as your (side markers).
Thanks!
