where is the fuel filter and how to replace it
Old 05-21-2011, 09:47 AM
apb
apb's Avatar
08 S550, 10 GLK350, 05 Clk500
for a 05 clk500? Thanks!
Mark Lutz (04-11-2021)
Old 05-21-2011, 12:43 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
I didn't need to replace mine yet and so I don't know where it is on the Clk500. But I did replaced one on my Clk430 and it on the rear passenger side above the suspension. You won't see the fuel filter until you remove the black plastic cover. So it might be hidden on the Clk500 or it might be in the gas tank. Dyno would be able to help you with a pic diagram.
Old 05-21-2011, 12:59 PM
buffyclk500's Avatar
clk500
in the tank
Old 05-21-2011, 03:01 PM
2MCHCAR's Avatar
Supercharged CLK500 & ML500
W209s are similar to W203s, I'm not 100% sure it's the same procedure but here is the W203 thread:
https://mbworld.org/forums/c-class-w...placement.html
Old 05-21-2011, 05:52 PM
M-bENZ's Avatar
Corrolla
not sure the 03 or 04 but the 05 CLK500 is in the tank ( i am 100% sure).
Old 05-21-2011, 06:47 PM
Klinh's Avatar
That's a 4 cylinders. How can it be similar with the V8? I think it in the tank because the Clk500 engine has the "returnless" fuel system.
Old 05-21-2011, 07:27 PM
Klinh's Avatar
Ok...i googled it and got a picture of the fuel filter. Definitely 100% is in the gas tank based on the pic. If it were a cansiter, then it would be mount inline like on the Clk 430.
Attached Thumbnails where is the fuel filter and how to replace it-121713879.jpg
Old 05-21-2011, 08:02 PM
M-bENZ's Avatar
Corrolla
brought the car to the dealer one time ( got my interior detail) and was planning to replace the fuel filter too but they wanted $600 i asked why they said because its in the tank so i was like "NVM" lol
Old 05-21-2011, 08:08 PM
Klinh's Avatar
You pretty much have to remove the rear seat for access to the fuel tank pump.
Old 05-21-2011, 11:10 PM
apb
apb's Avatar
Oh, that is not good news - in the tank. I will wait then...
Old 05-22-2011, 04:21 AM
dragon_27's Avatar
03 clk500, 06 qx56
lol i went to a dealership and they said the fuel filter has never ever been installed on the car lol
Old 05-22-2011, 06:36 PM
JHouse's Avatar
2014 CLS 550 & 2004 CL55
Do you mean never replaced?
My guess is it is big enough that they don't plan on it ever being replaced.
OTOH I had a 68 Ford that all it had for a filter was a screen right before the carb. I guess they though anything smaller was going through the engine. The mechanic pun an aftermarket in line filter in it after he cleaned out the screen (which was starving the engine for gas).
Old 05-22-2011, 06:49 PM
M-bENZ's Avatar
Corrolla
and your car still running ?
Old 05-22-2011, 06:57 PM
JHouse's Avatar
You really think they went into the tank and didn't find one? That part looked a little integrated and necessary to be just flat left off.
Old 05-23-2011, 03:01 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
I've seen used cars that have had them removed and not replaced but I'd be shocked if a factory actually forgot to put on on. Stranger things have happened though.
Old 12-28-2011, 06:41 AM
icyjay's Avatar
2003 CLK500
So.... has anyone tried replacing fuel filter?
I hit 60k and I am supposed to get it replaced, but it costs a lotta money due to long hours of labor so my mechanic said screw it for now and told me to come back when I have money.
Who actually got this thing replaced and how much did it cost?
And, has anyone not get this replaced ? I'd like to know what would happen if I don't get this replaced for another 3 years. Btw.... I have 2003 CLK500.
I think the fuel filter filters bad particles from gasoline you put at a gas station.
I put Chevron Fuel System Cleaner everytime I get engine oil changed (every 5k miles). I hope this is enough that I don't have to get the fuel filter replaced.
For those who are curious where it is located, I got a picture of fuel filter from parts.com
1) Fuel tank Clk320 clk500
2) Mount strap Mount strap Either Side
3) Cover
4) Filler neck Coupe
5) Grommet Coupe
6) Hose Coupe
7) Breather tube
8) Filler cap
9) Filler cap Seal
10) Sending unit Clk320 clk500
11) Fuel filter
Old 12-28-2011, 08:08 AM
Super Moderator
Glyn M Ruck's Avatar
Older models have the filter outboard at the rear of the tank. late 2005 onwards NON AMG cars started placing it in the one fuel level sensor in the tank. Fuel sensors & pump are under 2 round plates under the rear seat. AMG vehicles had it in the tank earlier. In tank units require replacement less often due to capacity.
External
Internal
Attached Thumbnails where is the fuel filter and how to replace it-w209-fuel-tank-attachment-parts.jpg
Old 05-04-2019, 04:38 AM
Yalin's Avatar
W209
Glyn, would you mind giving the code for the internal thing that should be replaced? I bought an old filter, seems like they couldnt understand what was going on with my car. One said there is no filter, indie couldnt find the location and handed me the old filter.
I am thinking of DIY if the part is not very expensive. My car is over 100K miles now.
Old 04-20-2020, 07:51 AM
JoiseyBenz's Avatar
2006 CLK500 cabriolet
I have a 2006 CLK 500 convertible (W209). Very confused about the fuel filter. I bought a new one 2 years ago (13k miles) when I acquired the vehicle, but due to my confusion I never put it in. Since I have some 'extra' time I'd like to tackle this.
The filter I purchased is 002-477-300-1, and is an external filter. That is the part# that every site I've looked at shows.
I changed my differential fluid yesterday and while I was in that area, I spent a little time looking for the fuel filter and could not find it. Is it perhaps underneath the long, black mud protector thingie?
Distraught !
Thank you
Old 04-20-2020, 09:36 AM
labguy's Avatar
2014 E350 Sedan
I have 143K miles on my 2008 CLK350 and the fuel filter has NEVER been replaced. I believe that I have read on another thread that due to high cost the advice was not to replace until you start having issues.
Old 04-20-2020, 01:42 PM
JoiseyBenz's Avatar
I'm antsy. I am very big on preventive maintenance. I enjoy working on my car. I have extra time on my hands. So, instead of polishing the bolts on my intake manifold, I'd rather change the fuel filter
If I don't get a definitive answer on the 2006 CLK500, I may take off that plastic cover next weekend to take a peek.
Also, oftentimes the "high cost" is due to the labor component. I've done LOTS of stuff on my cars over the years that would've cost me a small fortune to have someone else do it! Besides, when I do it myself I KNOW it was done right (errrrr ... HOPE it was done right).
Old 08-15-2022, 12:38 AM
AIKID's Avatar
E350 4matic
Any luck? Was it inside tank?
Quick Reply: where is the fuel filter and how to replace it
