320 CLK Cab Headliner Trim
Old 05-07-2012, 09:10 PM
Stuart320clk's Avatar
clk320 cabriolet
The plastic trim (bezel) attached to the headliner around the rear window of the convertible top is coming loose on one side. Several of the tabs for locking it into the aluminum frame around the window are broken off. In addition, the headliner fabric is pulling the trim away from the rear window during operation of the top, putting strain on the remaining tabs.
The headliner and the top are in great shape. All other aspects of top operations work fine.
Has anyone else encountered these problems and come up with successful remedies?
Thanks.
Old 05-07-2012, 09:39 PM
MBworld Guru
Rudeney's Avatar
Received 1,004 Likes on 872 Posts
NO LONGER ACTIVE
What year is your CLK? If its a 2003 or earlier, then you have a W208. The W209 doesn't have any trim around the inside of the rear window on the cabriolet.
Old 05-07-2012, 10:36 PM
clk320 cabriolet
It's a 2001. Thanks for the clarification. I'll post to the correct forum!
Though if you have any recommendations, I'd be most grateful.
Old 05-07-2012, 11:11 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
I was looking at WIS and it appears that the trim piece is glued in place. I can't find any details about "how" to glue it, but it mentions breaking the glue seal for removal. If you don't find any help on the W208 forum, check with your dealership parts counter - sometimes they know more than the service advisors.
Old 05-03-2013, 10:46 PM
Steady_shadow's Avatar
Clk 430 2000
That part number is 2087780133, I got it for 42 dollars including shipping, but you have to put the new one to the headliner and then click it back to the window. This part will crack offent after the sun hitting with out U.V protection, I always rather fix it with the way it was mean to be, just in case I would want to sell the car.
Old 05-07-2013, 04:42 PM
rossk's Avatar
w208
w208 rear glass trim
Hi all!
Has anyone found a way to attach the inner liner to the back glass trim?
Thanks in advance,
-Ross
Old 05-19-2013, 11:40 AM
clk320 cabriolet
Thanks very much for this info. The part number remains valid.
A question...how is the trim piece attached to the liner?? As best I can tell, it is sewn.
Stuart
Old 05-20-2013, 11:19 AM
rossk's Avatar
w208
@Stewart
No such luck, it has to be sewn into the plastic. It is difficult to find a trim shop that can do it. We had to replace the client's liner to resolve issue. Sucks!
Old 05-20-2013, 06:21 PM
clk320 cabriolet
Thanks once again. I hate to ask.....whats the cost of replacing the whole liner, and how much of a job is it to tackle this? Something a "do it yourselfer" might have a fighting chance at?
Stuart
Old 05-28-2013, 10:48 AM
kevinivan's Avatar
clk 430
Glue,
i had the same problem, i glue it and this is how i fix it permanently.
1) 3M Adhesive, Super Trim. Part Number: TRM-8090:
glue wont damage any material, and works to glue the convertible top.
i try so many and they all fail, so dont waste you money in any other than this. is also waterproof.
2)Un du Adhesive Remover:
just in case you didnt do a clean job, this can clean any extra exceeded work, also work great to remove the glue from the leather, plastic and glass, living the place like nothing even happen
3)heat gun:
use it for a few sec after applying glue, press fabric and let the the fabric cool, heat it again for a few seconds and press. do this for 3 to 5 times, in a small area at a time, i did this in a area of 3 to 4 inches long at a time.
Note:
this items will also help to glue the convertible top, or any material, i even took that ugly fabric in the bottom of the door that was coming off, and i put leather with this glue.
Old 05-28-2013, 10:58 AM
kevinivan's Avatar
clk 430
here is some pic,
this is what i use to glue. and it works great
Old 09-04-2016, 12:38 AM
johnmckenna@cox's Avatar
1999 CLK 320 Cabriolet
1999 CLK 320 Conv. HeadLiner
Upper Plastic Bezel Frame attached to Head Liner cracked.
Lower Frame Half - MB Part# 2087780133 is available.
Is the Upper Plastic Bezel Frame available separately or am I on the hook for
a new Head Liner?
Old 09-04-2016, 11:09 AM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
You have a W208 - check that forum as those guys may have better info.
Quick Reply: 320 CLK Cab Headliner Trim
