AC Blower Fan Stops and Starts
Old 04-18-2014, 04:39 PM
bonhamsurf's Avatar
2006 CLK 350 Convertible
My wife's 2006 CLK 350 Cabriolet has 22,000 miles on it and has had an A/C issue for awhile now. Whenever we turn on the ac, after about 5 mintues (and it's a random timie) the blower motor turns off. Then a short time later (2-5 minutes) it will just come back on. THe air is still cold and I can smell the freon/compressor in the air for the first few seconds it's back on, so I know it's not the compressor. It's a fan.
Anyone heard of this before? Suggestions? Thanks!
Old 04-18-2014, 11:46 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
It could be a defective blower motor or its "regulator". These are easily accessed by removing the paneling under the dash in the passenger side footwell.
Old 04-20-2014, 01:37 AM
bonhamsurf's Avatar
Thanks, I'll try this. Is it possible it's a bad relay?
Old 04-20-2014, 10:36 AM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
I don't believe there is a relay for the ACC fan motor - just fuse #51 on the front SAM.
Old 07-21-2014, 08:33 PM
sadovak's Avatar
2007 CLK550
I have exactly same problem...can you please share with us if and how did you fix that problem!? Thanks.
Old 07-22-2014, 01:13 AM
Bill51sdr's Avatar
2008 CLK 550 Cabriolet
My wife's CLK350 had this problem. I have replaced the blower motor and so far, so good. The regulator Rodney refers to is sold as a separate part, the old one has to be transferred to the new blower motor assembly if you will be re-using it. Fingers crossed that this part is not the actual problem...
Old 07-22-2014, 03:29 AM
sadovak's Avatar
2007 CLK550
Thank you
Old 07-22-2014, 07:55 AM
pskdude's Avatar
2004 CLK500 - W209 - Cabrio
Hello,
I had the same exact problem and changing the blower regulator fixed it. Was about 185 dollars.
Old 07-23-2014, 01:34 AM
sadovak's Avatar
2007 CLK550
Old 08-19-2014, 06:09 PM
sadovak's Avatar
2007 CLK550
no luck for my guys. I replaced blower motor and regulator but problem still persist
I did a/c test-reset but this time the lights never stop "blinking"
any idea? thanks
Old 08-20-2014, 09:01 AM
pskdude's Avatar
Damn, not good. I can only imagine it would be your a/c Cluster at this point.
The lights not stopping the blinking are because a flap actuator or lever arent working properly. Ive been trying to diagnose myself but will be taking it in to someone with SDS to see what error codes i pull...
Old 09-10-2014, 12:15 AM
sadovak's Avatar
2007 CLK550
update: guys, in my case it was light/sun sensor it's located at engine hood grill. it cost me $330 total
Old 09-10-2014, 08:42 AM
pskdude's Avatar
wow. how awkward that would affect your a/c ?
Old 09-25-2017, 10:48 AM
tallatghazi's Avatar
W210, E220, CDi, Sedan, 1999, Facelift
Hi, what was the actually issue diagnosed?
Please share...
Quick Reply: AC Blower Fan Stops and Starts
