Transmission Service
Looking to service my tranny -- some people say no to flush and only a pan drop and some say do a FULL flush! Whats the thought process here?
Also, if I go with just a pan drop is there a special way I should do this? do I just drop it and replace a pre-determined amount of oil or do I need to measure and replace exacly what came out? is oil temperature an issue before replacing or is that just for checking? where do you replace it diptisck hole or tranny side fill hole?
Thx in advance for your help!
MBworld Guru
Given that your 722.6 transmission was sold as "sealed for life", anything you do is better than what MBZ suggests. Personally, I'd do a pan-drop fluid and filter change every 40K miles. If you really feel like you need more than that, you can do a flush. Here are WIS docs for both:
http://benzbits.com/722_6/FluidFilterChange.pdf
http://benzbits.com/722_6/TransmissionFlush.pdf
2005 E55 AMG, 1991 MR2
I plan to do the same thing, just change whatever volume of fluid comes out, clean the magnet, new pan seal and check the plug for the wire loom while at it. A full flush risks dislodging crap in a high mileage car.
Super Moderator
A full flush of an unserviced transmission will always be the best possible thing you can do.
looking to do radiator and tranny service at the same time ...
one last thing, I'm gonna also replace the tranny "plug adapter" while I'm there ... any specific way to do this??
Thanks in advance for all your help!
Super Moderator
Your car only has 50K miles on it's 722.6 so a half change is probably OK unless the fluid is heavilly oxidised. Or you can do 2 back to back half changes.
If it has been left longer than that then a flush is mandatory. A lot of nonsense is spoken about flushing. If a transmission fails after working cleanly on it after a flush it would have failed anyway. You need to get all the oxidised fluid out & refresh the friction modifiers for smooth performance & long life.
Here is the electrohydraulic bush change.
http://www.installuniversity.com/mb/...ans_oring.html
Good luck!
Good luck!
Good luck!
Good luck!
is it worth it to buy a tranny dipstick? I heard you have to ck it at a specific oil temperature ...
Super Moderator
Yes ~ you need a dipstick & an IR thermometer to take the pan temperature.
I completely trust what you say, it just makes me wonder if there is a real correlation at all.
Super Moderator
There is no correlation. It is another urban myth that has somehow grown legs.
We have brought transmissions back from the brink that were so fouled up that they lost drive & a flush got them back into service.
Super Moderator
