reare tires
Old 09-28-2015, 07:38 AM
jdhiller's Avatar
2004 clk500 cab
reare tires
The inside shoulder of my rear tires wore through the steel belt almost to failure. I last swapped sides 10k ago and all looked good now this. what are the likely suspects in this. I put new tires on but don't want to ruin them. the car goes straight and seems to handle normally.
Old 09-28-2015, 09:01 AM
Yidney's Avatar
2008 CLK550 Cab
You swapped sides 10K ago but you didn't say how many miles on the tires total. My rear tires are nearly bald at 13K miles. The reason they wear first on the inside is called negative camber - the tops of your wheels lean in. A little bit of negative camber is normal. But MBs - at least this model - often have a little more than they should. There is no adjustment built in. It will be worse if your rear suspension bushings are worn. Depending on miles, get yours inspected if you can't do it yourself. But if they are OK, and your toe alignment is ok, your options are (1) get used to buying rear tires a lot like I do, or (2) buy a set of rear camber bolts. A vendor here sells them. Basically you are replacing the two top outside bushings with ones with an offset hole so they can be adjusted. KMAC is the brand I believe.
Old 09-28-2015, 12:43 PM
jdhiller's Avatar
2004 clk500 cab
They had 23k on them the tread was not bad the inside shoulder was scary bad.
Old 09-28-2015, 12:58 PM
Fatz's Avatar
2008 clk550 - Navigator - Frontier
I agree with Yidney..... If you have not modified your suspension (lowering) and the tire wear rate has changed, it is probably due to worn bushings.
Even before lowering my car, I was changing the rears every 12-14K miles. Lowering made changing necessary more frequently (10-12K).
If all is good with the suspension, make sure you buy your tires where you can get them prorated when you come back in 12K miles; or install KMAC bushings and adjust the camber.
Old 09-28-2015, 01:06 PM
Yidney's Avatar
2008 CLK550 Cab
If your wear is that bad inside compared to outside then you do need to check your bushings and your toe alignment. Mine wear noticeably more inside, but not nearly as much different as you are describing. My issue I think is within a range of what I would call a normal quirk of the car, but yours does not sound that way. You have an actual issue.
Old 10-12-2015, 03:42 PM
totita's Avatar
C230 K
My Michelin rear tires are almost gone. Fronts are almost new. Would it be OK to replace them with Continentals? TireRack has a sale on EXTREMECONTACT DW ($175) vs PILOT SUPER SPORT ($225). The threadware seems better on the Continentals too 340 vs 300.
The Michelin warranty is only 15K miles for staggered tires. Continental does not specify it.
Any other more durable max performance tires recommended by forum members?
How long do rear vs front tires last on a CLK 550? I'm new to the car ...
Thanks.
Old 10-12-2015, 03:47 PM
eteller's Avatar
2009 CLK 350
FWIW this Saturday I just replaced my two front Continentials. Both had broken belts, only 3k mi on them. Went with Michelin Super Sports.
Old 10-12-2015, 03:59 PM
eteller's Avatar
2009 CLK 350
Interesting:
http://www.mbca.org/forum/bad-continental-tires
Old 10-12-2015, 04:54 PM
Yidney's Avatar
2008 CLK550 Cab
Thanks.
What year is you car? You may get better wear on the 17" on a 2007 than the 18" on a 2008-09. I have Conti DWS and have had no issues, but rears are bald at about 13k - same with Michelin. I tend to start hard with increases wear. Fronts will last at least twice as long as the rears. Probably more.
Old 02-10-2019, 10:39 AM
SilverE5588's Avatar
2015 E63S, 05'E55-Sold
Sorry posted in the wrong thread
Old 02-10-2019, 11:54 AM
OR-CLK350's Avatar
CLK350 2007
I may be havings this exact issue w/rear tires and wanted to check if the busing you are referring to is the one circled in the picture (rear tie rod arm)... I know this is an old post... any help is much APPRECIATED!
Quick Reply: reare tires
