Drivers side Front parking light
I replaced the bulb but it still still out , is there a fuse of individual side? I know it would be strange but I have to ask. I took a test light tot he socket no power... So any help chasing this would be nice
Current is monitored continuously by front SAM. Test light won't help unless it's the correct wattage bulb and you switch the lamp on after you connect the test light. Easiest is use star
Star? what do you mean star is the star the 1,000 item ? would be cheaper to pay a stealership
MBworld Guru
Star = SDS = Star Diagnosis System (a.k.a. Xentry). This is the official MBZ diagnostic computer system that can scan and code all of the car's diagnostic systems.
What I'm looking for now is because I noticed to loose wires that connect to the assembly I'm looking for a connector maybe someone has one from a damaged vehicle it's got five white wires on it and it snaps into the headlight assembly two of the top wires number one and number two actually pull straight out turning off the headlight and that's a loose connection causing the problem so if anybody has a damaged part out vehicle I'm looking for that connector 2 inches of free slot would be nice I have a picture in case you're wondering what I'm talking about
If that's outside the lamp assembly I am wondering why the colours are all white!
Are you sure that is not some type of adapter harness that was fitted?
