Need Help with Bluetooth Adapter
Old 02-13-2016, 03:35 AM
Timewarpone's Avatar
05 CLK320 Cabriolet W209 & 2011 BMW X3
I saw this item on ebay: http://www.ebay.com/itm/Oem-Bluetoot...2A5bzg&vxp=mtr
Is this all I need to use my phone? Is there anything else needed? Thanks
Old 02-13-2016, 07:27 AM
Ptrigg17's Avatar
2009 CLK550 convertible, 2012 ,,E550 Cabrio, 2012 Audi Q5
Check thread further down "Bluetooth enable" this subject has been covered .
Old 02-13-2016, 11:43 AM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
If you have MHI port in the armrest compartment (see photo below), then yes, that will do it. However, this was a very rare option (due to cost). Most all W209's came with an option called "pre-wiring", but that's literally just he wiring harness and no all the "parts" needed to enable the phone interface. Those parts are about $1,000 + labor to install. Then you can plug in that puck and get Bluetooth.
Old 02-13-2016, 04:31 PM
Thanks Rodney, I do not have the MHI port in the glove box. I do have an AUX Jack in the glove box so I will have to go with something like this: http://www.ebay.com/itm/131597606356?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
At least it gives me Bluetooth but no steering wheel controls
Old 02-13-2016, 07:15 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
The MHI will be in the armrest compartment - not the glove compartment. But it's still unlikely that you have it.
Old 02-13-2016, 08:04 PM
I meant the arm rest.
Here is another bluetooth device I found on ebay: http://www.ebay.com/itm/Bluetooth-4-...4AAOSwnipWUtSK
Old 02-14-2016, 12:12 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Since you have a MY2005 that is post-facelift, there are some options. One is the mCar unit (www.mcar.us). I am not sure if they are still available, but it replaces the CDC and emulates it for iPod or USB music and also offers integrates BT handsfree and streaming. I have it and I'm fairly well satisfied. BT handsfree quality is not the best, but acceptable.
Old 06-30-2021, 02:01 PM
ahpajerry's Avatar
CLK 350
It looks as though my 2009 clk mh1 port is located on the back of armrest compartment not on bottom. Does this require a different adapter then I see everywhere?
Old 06-30-2021, 10:19 PM
Your best bet is to get into it and look at the part and take a photo of it. That is the only real way to tell.
Old 07-01-2021, 12:24 PM
ahpajerry's Avatar
CLK 350
Smile clk adapter
Thank you for your reply Timewarpone, The connection is located on the of the box, near the top. All the online photos show the adapter on the bottom of the box. I am concerned that it could be to long as no were do I see dimensions. Hope I am successful dnld photo, never sure.
Thanks, Jerry
Old 07-01-2021, 12:51 PM
This is the bluetooth adapter you need. But before buying it give them your Make Model & VIN and see if the feature is enabled on your vehicle
https://www.ebay.com/itm/23143258320...EAAOSwwTlUnMhw
https://www.ebay.com/itm/25500777157...QAAOSwZ0lgvRk9
https://www.ebay.com/itm/33380570249...4AAOSwezFgc-rg
I suggest looking first at these 3 auctions closely
There are many others on Ebay. Don't go through the dealer unless you really have to.
Old 07-01-2021, 02:03 PM
ahpajerry's Avatar
CLK 350
Thanks once again,
I have visited all of these on ebay but show it mounted anywhere but on the bottom. No dimensions, which would help. There are a couple that appear smaller and have a different look, color and shape. Sellers on ebay do not offer much dependable info. So I will take some of their info to MB. Hope to have an answer and that I will post here for others.
Old 07-01-2021, 03:59 PM
According to your photo the device will certainly fit. It slips on inside the arm rest. You just need the one for your vehicle. What year is your CLK350? Is it a convertible? Remember it will not play music from your phone assuming you have the OEM head unit it will only let you answer incoming calls. I ending up changing my head unit for a Kenwood DNR476S. https://www.crutchfield.com/p_113DNR....html?tp=20222
Old 07-01-2021, 07:24 PM
ahpajerry's Avatar
CLK 350
Phone module
Thanks once more,
I have a 2009 cab with "comand" w/single disc player. There is a changer not connected and an aux port that has been replaced with a multi pin connector. I have only had the car about three weeks. Once I have title in hand I will take it to an audio shop to see about the last two and maybe the phone. Not an automobile do it yourself person. I will also run it by MB dealer here in LV.
I really appreciate your taking the time to provide me with your input.
Thank you,
Jerry
Old 07-02-2021, 01:17 AM
thedeuce01's Avatar
2002 CLK430
What is the multi-pin connector you have in the glove box? Is it for iPhone/iPod connections? If so, you can connect a Viseeo Tune2Air to that and get BT streaming. I have that in my '11 ML and it works great.
Old 07-04-2021, 08:35 AM
draculr's Avatar
2009 CLK280
How did you fit that in your car? Do you have a picture of your dash after you've fit the new headunit? Does it work with the steering wheel controls and everything also?
Old 07-04-2021, 01:52 PM
I did the complete install myself. There is no adapter for steering wheel controls. iDatalink Maestro does not work with my vehicle. I searched high and low for months so I bought the hand held remote to control the head unit while driving. This Kenwood head unit is fully loaded. I bought it from Crutchfield including the dash mounting kit. https://www.crutchfield.com/p_120998...t.html?tp=3121 It even has back up camera capabilities which I installed and even has satellite radio capability. To many features to tell you about. Look at this link: https://www.crutchfield.com/p_113DNR....html?tp=20222
abqhudson (07-04-2021)
Quick Reply: Need Help with Bluetooth Adapter
