2005 SLK 5.5 AMG w KLEEMANN SUPERCHARGER
2005 slk amg 5.5
MY CAR SPUTTERS ONLY ON THE FIRST START UP AND FOR 2-10 MINS OF DRIVING. THEN, DEPENDING UPON OUTSIDE HEAT AND HUMIDITY, I RESTART IT, AND IT RUNS FINE (SPUTTERING STOPS). IT ALSO BACKFIRES ON DOWN SHIFTING UNTIL THE SPUTTER PROBLEM GOES AWAY (ONLY AFTER 2ND START).
THE PROBLEM NEVER GOES AWAY UNLESS I DO A 2ND START.
THE CHECK ENGINE LIGHT IS ALWAYS ON !!
GOTTA BE A FUEL DELIVERY PROBLEM AT THE COLD START.
CHOKE ? ECU CHIP? FUEL LINE ? FUEL INJECTOR ? ALWAYS THE 5th CYLINDER CODE.
ANY IDEAS ?
IF I NEED A NEW FUEL INJECTOR DO I GET MERCEDES STD PARTS OR KLEEMAN PARTS ? rrman9999@yahoo.com
ANY IDEAS ?
CLK55 '05 CLK320 '02
ANY IDEAS ?
ANY IDEAS ?
and are you sure you got a proper tune with instillation?
