Lights for sun visors
CLS 320 CDi
My lights in the roof for the sun visors do not work ive been told they get there feed from the normal ceiling lights and there is no separate fuse for them so cant be a fuse blown. It seems odd they both are not working (and yes ive tried them at night because of the sensor) and it bugs me I cant get them to work. Anyone got any ideas. Thanks Dave
Received 4,446 Likes
'71 Pinto
Pull the vanity cassette, odd but you “may” need to replace switch to both sides, part # 2118700510.
CLS 320 CDi
cls550, s320, 300se,323ic
I just had to remove the drivers side mirror for this same problem. I jumped out the switch and the light worked. I removed the switch and sprayed contact cleaner into it. It is now fixed.
CLS 320 CDi
Does the mirror just prise I tried before but it did not move out I don't want to break it.
Dave
konigstiger post with the red arrows shows where the tabs are. The glass and bezel assembly all come out together. Use a credit card or small plastic wedge at 2 of the tabs in the front or back and the assemble will pop out.
