2008 E320 Bluetec 140000 km: oil leak from drain hole
Old 10-06-2011, 03:35 PM
countryguy's Avatar
2003 VW Golf TDI
The leak was isolated to be coming from a small drain hole at the driver's side of the engine near bottom close to the transmission.
Mechanic who found the leak does not know what's causing the leak.
Does anyone know what could be the cause of the leak?
Thx.
Old 10-08-2011, 03:21 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Is it engine or transmission oil ?. Could be engine rear crankshaft oil seal leaking.
Old 10-08-2011, 10:35 PM
harkgar's Avatar
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
Thx.
A photo would help.
For 2008 MB transmission oil is red.
If it is leaking from an oil drain hole change the copper washer and see if it helps.
Old 10-10-2011, 10:09 PM
countryguy's Avatar
2003 VW Golf TDI
There is no red, the leaking fluid is black as engine oil - diesel engine oil because it's as black as it gets :-)
Old 10-11-2011, 02:35 AM
Carsy's Avatar
In my opinoin it is the engine rear crankshaft oil seal. Cannot understand why a mechanic could not diagnose the leak !!. That is his job.!
Old 10-11-2011, 11:06 AM
countryguy's Avatar
2003 VW Golf TDI
Thanks.
Old 01-12-2014, 05:26 PM
avbar's Avatar
2008 E320 Bluetec
Did you get this resolved? I've got the same thing on my 08 e320.
Old 02-06-2014, 03:41 PM
itaintoverever's Avatar
2008 Mercedes E320 BlueTec
I had my 2008 E320 serviced at the stealer recently, transmission filters and oil.
They said there was a leak at about the place described here. Said it is the oil cooler.
They quoted $3600 to replace the oil cooler assembly.
I looked up the oil cooler seals at Pelican Parts, $5.00.
Old 02-06-2014, 05:05 PM
avbar's Avatar
2008 E320 Bluetec
Yep. The MB mechanic told me that it was my oil cooler too. He said it was a scheduled 15 hour service plus $250 in parts because they basically have to remove the whole engine to get to it. Total estimate was about $2700 in St. Louis. I have no idea what I'm going to do yet, except keep cardboard on my garage floor.
Old 02-06-2014, 06:45 PM
I am thinking the Stealer here is off. I had an oil spill (changed oil and missed the correct place where the o ring goes) and got a bit of oil on the engine. Even after spending all day and the next cleaning up the spill I am sure that was that oil they spotted.
I pulled the plastic pan off under the engine and it was clean last week.
Note to self - don't do anything with this car without careful research!
Old 02-07-2014, 08:52 AM
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
I had a similar issue.
I got the oil cap on my GL320 a bit lopsided and it spit out about 1/2 quart or more of oil on a 200 miles drive.
The oil was all over the bottom of the engine and well soaked into the padding.
The dealer was "sure" I had a bad oil cooler seal.
I may have a few slow oil leaks but nothing that NEEDS $2K in repairs (yet)
Old 02-07-2014, 05:54 PM
SmokinReefer's Avatar
ML350
I just had the dreaded oil cooler leak repaired on my 2010 ML with 100K miles. It too was leaking out of the small hole in the rear of the engine. Took 2 days and $4,400 to fix. Since I just ordered another ML (gasser this time) they knocked it down to $3,600.
Parts guy said the cooler has been redesigned with higher temperature seals.
I think the better mileage of the diesel is offset by higher maintenance costs so I went with gas for the new one. I'm keeping the diesel though.
And last month I had to replace the AdBlue tank heater for $1,500 to get rid of an annoying CEL
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Quick Reply: 2008 E320 Bluetec 140000 km: oil leak from drain hole
