fuel shutoff valve
Old 06-08-2012, 12:17 AM
arturo71's Avatar
e300 diesel
fuel shutoff valve
Does anyone know how to troubleshoot a fuel shutoff valve on the OM606 engine (E300d mercedes)? it looks like a straightforward solenoid that opens and closes the fuel flow. However, it has a four prong connector, which I find confusing.
An electrical schematic would be helpful.
Any thoughts?
Old 06-08-2012, 08:07 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
MY take is ----Unless you are doing this(testing pin resistance) for educational purposes, the SOV has fault codes for failure. If you do not have a fault there is nothing wrong electrically with the SOV. Change the rear O-ring and be happy!!
Old 06-08-2012, 09:53 AM
arturo71's Avatar
e300 diesel
sov
That's good to know...well, there is no "check engine" light popping up, so I guess the sov is working, right?
Old 10-16-2016, 01:28 PM
reknez's Avatar
Mercedes w210 300td
Hi Plutoe, what is the fault code for SOV? Thanks1
Quick Reply: fuel shutoff valve
