ISO body kit for A 207
2012 E550 Cabrio
Gents:
I have a '12 E550 Cabrio and I want to put a four piece body kit on her to make her look more aggressive! I want a front spoiler, a diffuser and a side skirt (maybe)
I want fiber glass so I can paint it to match the body.
Who do u guys recommend?
Names and Pictures would be appreciated.
Thank you.
Thank you.
Prior design is a well-known one:
http://www.ebay.com/itm/MERCEDES-E-CLASS-COUPE-W207-BODY-KIT-E550-E350-E63-AMG-FRONT-BUMPER-LIP-DIFFUSER/181595416423?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20131003132420%26meid%3D4b58ed8a90d24b54a2ace6617d0663a3%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D221670029936&rt=nc
here's a knock off one I think?
http://www.ebay.com/itm/W207-C207-COUPE-BD-LOOK-FULL-BODY-KIT-FOR-10-13-MERCEDES-BENZ-E-CLASS/161651191847?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20131003132420%26meid%3D4b58ed8a90d24b54a2ace6617d0663a3%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D221670029936&rt=nc
PD also has a wide body version of their kit, but you mentioned 4 piece.
Revosport has stuff: http://www.revozport.com/w207/
MEC has one as well: http://www.mecdesign.de/w207-e-class-coupe-cabrio/ - edit: sorry, this is a widebody kit.
These are the ones off the top of my head. Lorinser and Piecha come to mind too.
Former Vendor of MBWorld
SL55 AMG
Prior Design makes the best kits!
Here are some photos of their PD550 E-Coupe kit!
Give them a call or email at 866-997-2336 or Info@priordesignnorthamerica.com
2012 E550 Cabrio
Thanks guys, I'll check'em out and keep u posted.
About how much should I expect to spend on 2 or 4 piece kit with one of these companies?
Polyurethane of some sort. You basically have that and fiberglass. Fiberglass doesn't flex much, cracks, etc. Polyurethane flexes so it's easier to work with for body shops, and doesn't crack. In smaller areas it can though. While painting, they have to add a flexing additive or something I think. So you run more risk of spidering and things like that in the paint.
Fiberglass can be repaired and altered.
The PD kit runs...4-5K I think? Then you have to consider installation with is mounting, any modifications/adjustments needed to fit, and painting.
2012 E550 Cabrio
It seems like most kits I've seen are FRP. Is that considered fiberglass or Polyurethane?
I'm liking the look of PD kit, but it's expensive at $4500. How is that knockoff copy for $2K?? Does anyone have experience with that one?
But if comparing the same materials, typically the authentic fits better. They still need adjustments, but usually less.
2012 E550 Cabrio
FRP is fiberglass. As someone who has had an authentic fiberglass piece versus a poly knockoff of the same piece, the difference was the material.
Even with the sideskirts though, rocks can put chips in fiberglass.
You may not have an option, I don't know if the prior design is available in polyurethane? but yes, if you can, I'd say poly for sure. The only real downside to me is paint might spider crack on you if it has to flex too much.
1 Post
2012 E550 Coupe
What am I missing? Isn't FRP a polymer [plastic] base ... Fibre Reinforced Polymer?? Not as strong as carbon fibre but not a true fibreglass product either. Instead it is a "polyurethane" that is reinforced by fibre to limit the pliability that others have alluded to when speaking of "polyurethane" issues.
I am not an expert and stand to be corrected, but that is my take on this conversation.
SL55 AMG
