E-Class (W114/W115) 1968-1976: All Models
69 250 ignition timing gear removal HELP!
Old 09-22-2016, 04:58 PM
mclong82's Avatar
1969 250/8
Hey Everyone,
I've got a single row timing chain M114.920 block 250 and I need to remove the timing gear that drives the ignition and oil pump.... does anyone know how to do this? The gear is bolted to the shaft and it appears to also be pressed on, but there isn't enough clearance to actually remove the gear. I'm sure there's some magic process to get this thing off.... Thanks for any help you can give!
Old 09-22-2016, 06:49 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Although not totally applicable you may find some tips in the attached
File Type: pdf
mclong82 (11-03-2016)
Old 11-03-2016, 01:23 PM
mclong82's Avatar
1969 250/8
Thanks for the suggestion but my block seems to be laid out a little differently (Plus it's a single row timing chain). Here's a quick pic of the area i'm talking about. I apologize it's not a close up, I didn't foresee this problem when I was taking pics.
In the pic I circled the access port i'm talking about. Within that access port is a timing gear that drives the oil pump and distributor. Unfortunately The gear is larger than the access port and i've got no clue how to take this off........ I'm trying to install my new timing chain but it's a sealed chain with no master link......... My other (and preferred) solution would be to find a master link for this chain and cut it. Anyone got any ideas???
Thanks!
Igniton timing gear access port
Quick Reply: 69 250 ignition timing gear removal HELP!
