Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| E-Class (W124) 1984-1995: E 260, E 300, E 320, E 420, E 500 (Includes CE, T, TD models) |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 300E (w124) -87
#2 |
Drives: 95 E 320 Cab
Try plugs, fuel filter, EOM
no message
#3 |
Whats an EOM?
#4 |
EOM means end of messge. EOM
#5 |
Once mine was doing something similar. It would hesitate and stall at random times. It turned out to be an electrical problem. The main computer box or something needed to be replaced. Get somebody to test that and see if it's the problem. They might be lazy to do it, but get them to do it anyways. My dealer was like...Well we'll have to take it somewhere where they have the machine to test it. Don't let them just keep replacing parts. Get the computer tested.
Level8Drummer 87 300TE (For Sale) http://www.hephaestusdesigns.com/mercedes.html |
#6 |
Drives: 2003 E55 1982 300dt
My 1986 300E started to do what you are describing. I changed the plugs...they were worn to about .070. and I also changed the distributor cap which was the most worn cap I have ever seen. Since then no further stalling out at return to idle.
#7 |
Well, So far i have replaced the plugs (BERU Ultra-X).
Managed to crush something in Cable nr 5 , so i will have to get a new one. The car runs a little "unsmoothly" now, jerking back & forth. hehe. However the problem is still there, but i will replace the fuelfilter as well. Had some problems finding it, but i know where it is now. I replaced the Distributor Cap & rotor a while ago because the engine was misfiring sometimes when starting. If it still won't work after the fuelfilterchange i will get the "computer" checked. I don't think that one is gonna be cheap if i have to replace it. When you say "computer" do you mean the Control Unit for the injection?. Because AFAIK there seems to be more than one Control Unit... Last edited by Sweenie; 02-27-2002 at 07:28 AM. |
#8 |
Hi.
I'm just wondering if a leak in the vacuum-system could cause stalling problems? I'm thinking of checking every vacuum-(hose,tube?, Don't know what they are called). |
#9 |
Drives: BENZ
Stop stalling
Dont just replace parts to replace parts. A good tecnition can diagnose this problem in about an hour. It could be plenty of things. Start with the overvoltage protection relay. If it is an old seimens with a white top, replace it anyway. It is located behind the battery near the fuel computer. It could also be the fuel pump relay. If you jump terminal 7 & 8 & it still stalls then you can look elsewhere. These are the most common culprits.
| Tags |
| 1986, 300e, 87, dies, dying, engine, low, mercedes, overvoltage, protection, relay, rpms, sel, stalling, stop, w124 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
