W124 E220;Need Help with Air Conditioner.
Old 01-31-2015, 08:05 AM
Akkizma's Avatar
W124 E220
Hi Awesome People,
Long time; I had got a W124 E220 about 6 months ago.
The AC works, but the system is currently running without a KLIMA/Compressor cut down relay, due to which Ice forms on the pipes after usage of about 5-6kms on the highway, and it stops blowing air.I have to turn it off for a few minutes, and then turn it on to make it work.
Now the problem is, that its becoming really difficult for me to find a new KLIMA relay here,almost all donor cars i have come across, either have a broken relay or one that has already been yanked off the car.
With the current set up in my car, i believe the compressor is working continuously, which might lead to it getting bust; correct?
Is there any work around to make the system work properly till the time i get hold of a KLIMA relay.
Old 01-31-2015, 09:23 AM
optimusprime m1's Avatar
W124 260E
INFO
Akizima is the relay like this one.Can you tell me the numbers on the top.
Old 01-31-2015, 10:02 AM
Akkizma's Avatar
W124 E220
Yes, thats the one.
The one on mine has Part# 0035455405
But that is not available.
I am getting 0035455205.
Will it work?
Old 01-31-2015, 11:16 AM
W124 260E
help
Akkizima i would not like to say.I would keep asking , you never know the part number may have been updated. You never said the year.
Old 01-31-2015, 11:35 AM
W124 260E
hi mate the number i gave you is wrong it as a number4 to many it is >0035455405 <
Old 01-31-2015, 11:44 AM
W124 260E
Originally Posted by Akkizma
Yes, thats the one.
Will it work?
this number is the right one 0035455405 as you have on your car. Dont know about the other. I can see if my mate as one for you.
Old 02-19-2015, 09:40 AM
Akkizma's Avatar
W124 E220
So i got hold of KLIMA relay for my car.
Not OEM but KAE brand, can anyone help with the AC wiring diagram for W124 E220?
Old 02-19-2015, 10:11 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Yes, but what is the VIN and what are you looking for specifically repeat specifically.
Old 02-21-2015, 08:34 AM
Akkizma's Avatar
W124 E220
WDB1240226C273672
I didnt understand, as to what you meant by repeat specifically?
I am just looking for AC wiring diagram for my car.
Old 02-21-2015, 09:20 AM
W124 260E
WIRE
Hi go to Google search engine if you cam put in ---
Mercedes E220 Wiring Diagram . And you can find answers to all problems if you can use it .-Google that is.
Old 02-21-2015, 10:05 AM
Plutoe's Avatar
1999 E300TD
WDB1240226C273672
My reason for "Specifically" is because the AC system is on loads of wiring diagrams---what is your electrical problem or what do you think is your electrical problem and I will check to make sure that item is included
Old 02-21-2015, 10:06 AM
Plutoe's Avatar
1999 E300TD
Then post it!!
Old 02-21-2015, 10:52 AM
W124 260E
info
Pluto go there your self,as
i have been on this case for hours now. He will have to subscribe to the site as i dont need it my self i have not done so. Its a PDF document to download.
Old 02-22-2015, 11:19 AM
Akkizma's Avatar
W124 E220
Hi awesome folks,
I had managed to locate AC troubleshooting documents.
Didn't need them in the end, as i found a competent guy to work on it.
Fixed the wiring and installed the KLIMA relay, it works as expected, and i am a happy soul.
I paid $5 as labour to get it fixed(labour is cheap here)
Old 02-23-2015, 05:42 AM
W124 260E
aircon
Thats good you have it up and working now .Look out for you the next time.
Quick Reply: W124 E220;Need Help with Air Conditioner.
