vacuum diagram m103 260e
Hi Can i ask if a member could just pop his hood please , and check for me the locations of the vacuum pipes from the thermo time valve .It sits on the right side of the cylinder head in UK cars just above the coolant pump .From the top of this valve it as 2 connections comeing out of the top ,the one is on an angle ,and the other is upright, This will tell me where the pipes plug in to on the items in the engine compartment . Rrealy need to find out what they both go to . Like the up right one goes to - And the one on an angle goes to - I cannot find a vacuum line diagram,been looking for 3 hours , Thank you ..
VACUUM
Pluto no my friend i live on the sinking island -- United Kingdom .In a little village called Worcestershire on the River Severn..
nice one
Pluto very nice of you to help.I have most w/ manuals but none cover vacuum . My vin is WDB1240262A941387 Mercedes w124 260E 1989 Auto .Thanks again for your help.
Well there is good news and bad. The good a learned about your 103.940 engine.However while using WIS to search for a vacuum document---there was none. When you search for vacuum you get climate control, transmission vacuum control, MFA manifold vacuum assist, and central locking---Then I use my favorite starting point-"mixture" even with that search you get emissions and transmission shift retard points------so I am in the same position as you---however I would start looking at all the emissions components
good
Pluto thank you for taking time to search for the vacuum diagram. If you have had a problem ,then i will have no chance to find one . So i will do as you said and do a search. Regards Trevor
