94 e-class straight six 320 wont start
e class 320
hey, my name is chris and I'm trying to get some help,, so I did a motor swap on an e-class 320 94 straight six cylinder, I didn't take the harness of the motor just disconnected from the computer and reconnected it back to my computer, I hooked everything up back up and checked it twist tried to crank it and it wont say anything,,
e class 320
e class 320
e class 320
W209, W124
If you want help you may need to explain yourself better.
"cranking" usually means "engine being spun by starter motor"
"turn over" is used 2 ways, some use this to mean "engine being spun by starter motor" while other means "engine spinning via starter motor, then starts running via combustion".
Take a few moments to explain things clearly and you will have more luck getting help.
On older starters, there were a few ways to "jump" it. 12V+ to the post that energizes the solenoid being one, 12V+to the starter main lead being another.
e class 320
Thanks but i got it running now runs good and strong may be the best work I've done,, my costumer is very satisfied with it,,, he had bought it out of the junk jard and I basically rebuilt it for him, and had fun doing it. Thanks for the help guys
