FlatlineEF9's W210 Rebuild thread
#52
2001 E430, 2002 ML55
-with eibachs, camber and rubbing was NOT an issue. could turn from lock to lock and no problems. I was running 18 inch monoblocks at the time. Camber wear was about as even as stock. Even at stock, our rear has a lot of camber. Stock specs are around -2.5 degrees.
-I don't have any pics of the ksport setup, but I am going to test fit my BBK this weekend and I will take a few pics then. Basically a spring and adjustment sleeve replaces the springs. the PSS tires are the best all around tire I have ever used. wet and dry grip is amazing. Here in Hawaii we get a lot of heavy rain in the wet season and these tires have never let go on me...even with hard acceleration, cornering, and my current 4 inch drop lol. They are pricey, but less expensive then my former favorite, the pilot sport two. If you opt for PSS and eibach/koni...be prepared because your car will be transformed to a real sporty beast.
The springs and shocks are sitting at home and waiting on other hardware/tools to arrive. Been looking at more stuff such as control arm bushings and I've learned that we can adjust camber with special bushings...thought it was interesting. Kmac has some but they cost quite a bit.
I'm going to be running my stock E430 rims with winter and the monoblocks with summers...maybe PSS if the funds allow hah.
Any luck getting some photos of the coilovers?
Also what did you do with the rear bumper where the exhaust tips are? I have an E55 exhaust on and just put a spacer on the mount so it hangs under the bumper. I'd like to get an AMG rear bumper to have the tips look right or was thinking of a lip from ebay?
http://www.ebay.com/itm/1996-1999-Mercedes-Benz-E-Class-W210-4DR-Duraflex-BR-S-Rear-Lip-Under-Spoiler-Ai-/400615783321?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d468fbb99&vxp=mtr
Where you get your brabus bits from? though to find from my experience ha
#53
Sweet!
1996 1999 Mercedes Benz E Class W210 4DR Duraflex BR s Rear Lip Under Spoiler AI | eBay
For the rear bumper, its a brabus rear lip. Most people think I only have a brabus front lip, mostly because the sides and rear look pretty factory. The brabus rear valence comes with a cutout already...but I did have to have a muffler shop adjust the tips.
My lip kit I bought used back in 08 from a guy in socal, I realize how lucky I was to get it now...its super rare. wheels are still being made by brabus, so it was just a quick call to them to pick them up with the centercaps. Brabus USA has NOTHING left for our cars...so ive been working with them finding other older model parts that might fit...example, my shift knob is actually from a w220, my steering wheel is from a w208, and my hood emblem is from a 140, doorpins from an A class.
I also have a friend in Germany who is keeping an eye out in the local market for parts for me.
#54
Siopialover *sp has an amg exhaust on his stock rear bumper. Might want to ask him what he did to fit it.
#55
Test fit the S55 brakes today. They work...gonna get the calipers sprayed and ill post up pics. The calipers are kinda beat up and don't look too good in their present condition.
Also fit 5mm spacers front and rear.
Edit: Pic for serbnerd
#56
Got some dirty rolling shots too. Just had the car inspected last month. Car is fully legal now, but I had to strip the tint and get it redone in a lighter shade.
#58
Front right now is oem size brembo slotted rotor and stoptech pads. I purchased 345mm C55 rotors and 02 S55 calipers which will be thrown on after I get the calipers resprayed.
Rears are still stock. Will do a BBK on them soon, but first I just found out I have to replace a rear subframe bushing
#59
Had an issue over the weekend. Heard a clicking noise and found out that for some reason my lugnuts weren't torqued :/ either I forgot to torque one side of the rear properly, or its a stud issue
Will be posting pics later. Stud kit to be replaced tomorrow.
#60
are you replacing with regular bolts?
#61
Late update. Got an alignment last week.
Ridin smooth now
Gonna do another alignment after I get the camber kit for front and rear.
Ridin smooth now
#63
Christmas fun. Replacing the stud that broke off Replaced the stud...now shes back on the road.
#64
Another thing that's been bugging me. When I did my OEM xenon conversion, one of my headlights was from a 99 and the other was from a 96. The 96 one had some yellowing of the lens where it was melted. Took me 9 months but I finally found a suitable cheap lens on ebay. Hard to find the driver side. Did a lens swap last night.
Before. You can see the yellow and the slightly melted part.
To remove the clear "diffuser" or whatever its called, I simply used a blow dryer for a few minutes on the 4 tabs that were glued in. I was going to attempt the baking method (200 degrees in an oven) but the blow dryer worked out well, so I didn't have to resort to that.
Difference between the two parts. Holy moly that thing is yellow.
New part. nice and clear
I cleaned out the holes for the tabs and used a clear epoxy on the 4 mounting tabs. Clear headlight again.
Finished product.
Will have some pics on the car after I wash her. Been kinda dirty lately.
Finished product.
#65
#66
#68
No prob. The blue one is the one I used. I only put it in the first 3 threads that go into the hub. You can avoid lugnut seize by putting spark plug anti-seize lube in your lug nuts too. Comes in handy if you take your rims off a lot.
#69
thanks, i do take them off alot.
#70
So I put Pad1 on front and Pad2 on rear and car sits nicely. The einbachs are whole bunch stiffer so bye bye comfort on slow bumper roads hah.
Keep up the pictures!
#71
@serb nope its not complicated at all. Will keep pics coming...brakes are being sprayed as we speak.
#72
Just washed her this weekend.
Picked up the calipers last night...so after some goodridge brake lines and new pads, ill throw em on
#75
I got calipers from the 02 S55 AMG which look very similar to the C32 brake calipers. I am going to need to put about 1/2 inch worth of spacers on the caliper bolts though to line up the caliper and rotor properly though.
