Is there any MPG gain/loss in S or W mode?
Old 12-14-2014, 02:31 PM
DamianSicks's Avatar
1997 E320
Is there any MPG gain/loss in S or W mode switch on the shifter?
Old 12-14-2014, 02:47 PM
RichM's Avatar
2 2001 E320s, 2005 E320 4Matic
W or winter mode starts the car from stop in 2nd gear, and changes shift points to get to the higher gears more quickly. It also changes reverse to a slower ratio, but I have never noticed a difference in reverse. Don't really know if driving in W mode changes the MPG. I take a big hit in MPG with winter blend gas. On my cars I keep at my home in Michigan I see a 2-3 MPG reduction from summer gas. Not as big a hit on my Texas cars, but definitely noticeable.
Old 12-14-2014, 04:02 PM
southernwake's Avatar
A teal Vespa with tassles and glitter. You know you're jealous.
I would say that if there were any gain it would only be a tiny amount at best. Its purpose is reduce the chance of wheel slippage in wintery weather.
Andrew
Old 12-15-2014, 01:26 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
You will get better MPG if you keep the cars stored in the winter or take longer trips in the winter,however I doubt any measurable MPG loss or gain could be attributable to transmission mode.
PS: you will get better long term results if you use the time you have spent conjuring up this post----by reading to children!!
Old 12-17-2014, 12:28 PM
renault12ts's Avatar
W215 CL500 2005
^ Roughly translated as "no".
Though, I have no idea what the eels have to do with it...or maybe he meant "conjuring"?
Quick Reply: Is there any MPG gain/loss in S or W mode?
