Extra Work Light BAR where is the existing high beam relay?
I have bought an extra light bar for my 1999 W210T since I do not think the standard light is enough when driving in the winter times. I have planned to mount it under the license plate maybe inside the front spoiler maybe I do a cut-out in the front spoil I do not know yet.
I will make separate power for it but the bar has to work with exist high-beam and to do that I need to find the existing relay for the high-beam anyone know where its located? exactly?
http://www.ebay.de/itm/120w-21-5-LED...3D331486281442
Also I did the front light make-up and it turn out great but its still not enough light for me .
https://mbworld.org/forums/e-class-w...ml#post6428316
You know the switch that you turn on your head lamps and then turn on the high beams--then the front SAM(drivers side under hood) provides the voltage!!
PS----move closer to Belgium!!
