Maintenance items - ATP, Bando, Beck, Dayco, Gates, Uro or Wix?
I've been told my 2001 S210/W210 E55 AMG Estate will be arriving next week, therefore, I've already started ordering the parts that I will need for a full service, assuming they haven't been changed already.
So far, I've ordered the following:
2 X Mann Air Filters (C34104)
1 X Mahle Fuel Filter (KL82)
1 X GMB Water Pump (1472220)
1 X set of Mann Cabin Air Filters (CU2745-2)
I'm now about to purchase the following and this bit has me confused since I don't want an inferior quality product just to save a few Dollars. Also, bear in mind that these are the items that Amazon allows me to order Internationally to UAE, hence the shortlist:
1) Serpentine timing belt
a) Dayco 5060940 Serpentine Belt
b) Gates K060942 Mutli V-Groove Belt
c) Bando 6PK2385 OEM Quality Serpentine Belt
2) Pulley
a) Continental Elite 49073 Accu-Drive Pulley
b) URO Parts 000 202 Belt Idler Pulley
c) ACDelco 38083 Professional Idler Pulley
3) Tensioner
a) Gates 38083 Tensioner
b) URO Parts 112 200 0970 Belt Tensioner
4) Thermostat
a) Motorad 458-192 Thermostat
b) Stant 14569 Thermostat
c) Beck Arnley 143-0812 Thermostat
d) Gates 33930 Thermostat
5) Oil Filter
a) K&N PS-7004 Pro Series Oil Filter
6) ATF Filter Kit
a) Beck Arnley 044-0371 ATF Kit
b) Wix 58845
c) ATP Automotive B-217 Automatic Transmission Filter Kit
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
7) Others
a) Bosch 0280217810 Air Mass Sensor
b) Gates 38174 Belt Tensioner Assembly
Amazon.com: Mann-Filter CU 2745-2 Cabin Filter for select Mercedes-Benz models -Set of 2: Automotive
2) Pulley
3) Tensioner
4) Thermostat
5) Oil Filter
6) ATF Filter Kit
b) Wix 58845
7) Others
Maintenance parts
Hi,
I'll share with you my experience/choices for my E320 repairs.
I do a lot with Amazon and have used AC Delco and K&N oil filters, but my last change I used Mahle which I liked best of all.
Air filter, cabin filters and fuel filter: Mann
Charcoal filter purchased through Amazon. Don't remember the brand but they fit perfectly. I am waiting on a Gates fan belts through Amazon and just installed a Gates upper radiator hose which fit well. I have order coming from RM European for a Febi tensioner $70, and Truckman grooved idler pulley $11. (free shipping and no tax) I researched both pulleys and decided to go with Febi since it's well known and a direct European replacement part. Truckman also makes the idler pulley but more expensive than the Febi, so since RM European offered the Truckman idler pulley for cheap, I went with it.
I can't comment on the quality since I don't have them in hand, but feel I made the right choice. I purchased a Gates radiator tank cap and didn't like the way it fit (seemed loose) so it's going back to Amazon. I have not purchased a transmission filter kit, but had my eye on the Beck-Arnley kit.
I am a retired tech and have used Beck Arnley parts since the 70's with favorable results. I did my tranmission fluid change yesterday using a "Topsider" vacuum type fluid extractor. I was able to extract 3 1/2 qts using the dipstick/vacuum method. I did a refill with the same amount I took out and then did it again after running the car for a short time. The fluid looked good after doing the extract/replace method. I used Valvoline MaxLife automatic fluid which is approved by MB. Autozone $20 gallon. Coolant used was Zerex G05 also approved. These are my personal experiences which mostly worked out well with the exception of the Gates radiator cap and the dipstick tool I bought from Amazon (EWK brand) where the measuring tip dislodged from the cable and is now stuck either inside the dipstick tube or in the pan. The tool worked for 6 or 7 uses and the trans was at the correct level. I decided to check it one last time after having cleaned up the garage. The last test resulted in pulling the dipstick tool out and finding the plastic measuring tip had gone missing! My experience tells me it wont hurt anything and I'll deal with it next time I pull the trans pan down. Hope this helps.
Update
I did the conventional transmission service a few weeks ago and used the Beck Arnley kit which fit fine. I also repalced the connector plug since trans fluid was weeping up the lines and contaminated my TCM. I was able to open it up and clean the fluid out using electronics cleaner. Also cleaned the harness top and bottom and was able to fish out the broken measuring tool tip. I had to remove the dipstick tube to get at it. Everything back together and working great. Noticed axle boots torn and one front shock leaking. Ordered Bilsteins from RM European (they had the best price) and two new half shafts, ball joints and sway bar bushings. Cost $460 shipped. All parts are installed and car feels great. Now working on replacing brake lines since they are very rusty (not leaking yet) but I'm for preventive maintenance. Also replacing rear hydraulic shocks with a kit from Strutmasters $530 delivered. Consists of springs and bilsteins to replace the hydro system. Too many rusted lines and various parts prone to fail due to rust. I plan on re-routing hydro lines back to PS pump and bypass all the rusty lines in rear.
I'll update with pictures soon.
