Not signal in Ignition Coil #1
MB e320 1997
Hi guys,
I have a 97 MB e320 (I6 Engine) with misfire problems, without signail in ignition coil #1. I changed that coil with a new one and nothing (the mechanical guys said that the ignition coil was the problem). The car start without problems, but shakes and it has not the normal power. And also the position from the transmission shifter warms up a lot.
I change the spark plugs and also the wires.
The compression is OK.
My next step would be...
* change the sensors camshaft or/and crankshaft, but here my questions:
How can I be sure of what sensor is the bad one?
What else could be the problem?
