Need HELP - Central Locking System
Old 09-13-2015, 11:55 AM
ray1hockey's Avatar
Hi All
I have a 1998 E320 W210 Sedan and last week the Central Locking System stopped working. It will not work from the FOB, the interior locking switch or when I use the door/trunk key. Also the trunk switch on the dash does not open the trunk
I checked all the fuses and the PSE does run for 3 seconds then shuts down. I checked all the lines going to the actuators and there are no leaks. I tried replacing the PSE pump with no results.
When I use the key FOB the lights do blink once for open and 3 times for close. When I try to lock it with the FOB the little LED on the interior door lock switch also blinks.
All the door switches are fine since all the courtesy lights work when i open them.
I'm really at my witts end. If i hear my wife one more time complaining the doors don't lock I may kill myself. Does anyone have any ideas?
Old 09-13-2015, 07:02 PM
01BlackE320's Avatar
01 E320
Originally Posted by ray1hockey
Hi All
Did the original pump get wet? When mine failed, it was actually some of the pins on the plugs had gotten wet and burned up. I found a used pump that had the plugs intact. I spliced it in and it worked fine. Check the pins on your connectors. Perhaps the live leads are burned up and you're not getting power.
Also there are a lot of fuses that power that thing for some reason. Some are under the seat and some are under the hood. Check them carefully
Old 09-13-2015, 08:01 PM
ray1hockey's Avatar
The area under the rear seat is bone dry. I checked all the fuses (I believe there are 5 or 6 that effect the central locking system) and they are good also. The pins on the sockets on the PSE are clean and not corroded. Any other ideas?
Old 09-16-2015, 01:32 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
When you start up and exceed say 5mph to the door locks close??
Old 09-16-2015, 04:41 PM
ray1hockey's Avatar
NO. They do not lock
Old 09-16-2015, 06:52 PM
Plutoe's Avatar
1999 E300TD
You have a faulty PSE pump---Don't be fooled into thinking a used one will do the job--they are wrong--- get the part number for yours and accept no other used substitutions!!
Old 09-16-2015, 09:19 PM
ray1hockey's Avatar
The used PSE pump I installed was the exact same part number as the one I removed. It behaved exactly the same as my original one where it runs for about 3 seconds and then stops. I have a 2000 E320 with a working locking system. Do you think I should remove the pump from that car and try it in the 1998 E320? I read in a few posts that these pumps have to be coded. Do you know if this is true. Thanks
Old 09-17-2015, 05:15 AM
Plutoe's Avatar
1999 E300TD
My suggestion is you you stop wasting your time and money and have the car diagnosed like you should have in the first place.
Yes the PSE is typically variant coded to the car!!
Old 09-17-2015, 05:44 AM
01 E320
My pump failed and I bought a used one on eBay with the same part number and it worked perfectly. I was told by multiple members that it's plug and play. Since you replaced it and it did the exact same thing I believe you pretty much ruled out the pump. I think you need a Mercedes tech with access to the Mercedes diagnostic equipment
Old 07-15-2016, 06:40 AM
Nw208clk32's Avatar
W208 2000 Clk 320 cabriolet
If you find out why the doors didn't lock let us know please. I think mine is the pse pump but I didn't think that was your problem.
Old 08-24-2018, 12:23 PM
Patrick Trollen's Avatar
2001 E320 wagon rwd
final outcome?
Hello Ray, I was wondering if it ever came back? I think I have the same issue. Could you please call or text me at 651 - 214 - 0294
Or email Patrick trollen at gmail. Com thank you.
Old 08-27-2018, 01:05 PM
2001 E320 wagon rwd
Never never mind, my motor is bad.
Quick Reply: Need HELP - Central Locking System
