E-Class (W211) 2003-2009
V1 install
Old 08-25-2010, 07:42 PM
  #76
Meeyatch1's Avatar
'94 NSX,'99 NSX Z,'12 C63 Black Series (Prior: '07 E63, '08 CLK63 Black Series,'14 E63-S & 16 C63-S)
Originally Posted by Randal70
You should have bought the 9500ci...
Why post something so utterly pointless and off topic?
Old 09-29-2010, 09:55 AM
  #77
Meeyatch1's Avatar
Anyone else done this in an E63 that can help me figure out the wiring question?
Old 09-29-2010, 11:15 AM
  #78
Mackhack's Avatar
I don't think people (incl. myself) like to pull information for you and realizing that you don't pick them up.
Sorry!
Old 09-29-2010, 07:46 PM
  #79
Meeyatch1's Avatar
Sorry!
Man....how many times do I have to tell you I am sorry? I got super busy with some personal matters that are none of your concern, and SORRY, but the V1 install took a back seat to that. You do not have to keep posting to sh*t on me because of it. Have you never goofed or spaced out on something? Friggin' heck man.
Old 09-29-2010, 10:58 PM
  #80
Mackhack's Avatar
I'm not ****ting on you but do you see that I'm the only one who keeps reading your whining posts? Nobody else offered to search the docs for you to help.
If I have some time next week I'll check into your problem again and generate another pdf set for you! If not then keep posting and it keeps showing up on my screen to remind me! We're all busy not just you but when I send you 2 PMs/emails about this and I don't get any response then I truly feel like you never meant to seek help and I wasted my busy time. Thought about that? No? Then you might wanna do this now!
Old 10-30-2010, 01:44 PM
  #81
achtung6's Avatar
Thanks for the instructions.
I got my V1 installed this morning in about 30 minutes using your instructions! I'm very happy with the result!
Old 11-07-2010, 06:25 PM
  #82
asp323's Avatar
2006 E350
Great write up. Installed my V1 in about an hour, most of which was due to me being mechanically impaired. Overall easy install
Old 01-22-2011, 06:07 AM
  #83
Scanman's Avatar
E350 & 750i
Great write up!
MB newbe & I just found this site- it looks like I’ll learn a lot from you guys
Old 01-27-2011, 09:02 PM
  #84
cecil510's Avatar
1998 SL 500
Thanks! Great install guide
Old 02-20-2011, 03:03 PM
  #85
taurran's Avatar
04 E55 AMG, 03 350z Track Built/Single Turbo
I just did this today in about 15 minutes time. I tapped the hot wire onto the red wire from the cigarette lighter, and the ground onto the brown wire. Fired right up perfectly the first time.
Old 04-13-2011, 10:03 PM
  #86
conspawn's Avatar
audi
Having some trouble with the taping of the wire, not sure what I am doing wrong, popped the ashtray, got the red wire, spliced into it, hooked up to the v1 hardwire kit, but got no power...when I plug the radar phone wire to the cigarette lighter power source, starts right up...when plug into the hardener...nothing...any ideas what I am doing wrong? Any help is appreciated. 08 e350..
Old 04-13-2011, 10:52 PM
  #87
Mackhack's Avatar
Fuse in the hardwiring kit bad? Switched power rather than steady plus?
Old 04-13-2011, 11:14 PM
  #88
conspawn's Avatar
audi
I would think a fuse could be bad...but i have 2 hardwire kits...both get nothing...what do you mean by switched power vs steady plus? there are 3 wires red, white, and brown...i tried both red and white..got nothing...i know the radar and the wire work fine, and the cigarette lighter plug has power, leads me to believe prob something wrong with the hardwire kit...
Old 04-13-2011, 11:19 PM
  #89
Mackhack's Avatar
First you should have never just "tapped" an original cable loom to begin with. Doesn't really work well as you see. I would always build a little adapter so you can unplug your device from the original loom without damaging it.
Second: Switched power = power only when KL15 is on; steady power = you have 12 V at all times regardless whether the key is in pos 2 or not
Third: Have you heard of the tool called (digital) multimeter? You should have measured the brown, red and white cable to see what you have and what you need.
Hope that helps!
Old 04-14-2011, 10:11 AM
  #90
conspawn's Avatar
audi
Figured it out! The issue was teh ground wire...i had it under a screw, until i tapped the brown wire(ground) with my ground wire, i had nothing....ones tapped the brown, it powered right up. Thanks for all the help!
Old 04-14-2011, 10:41 AM
  #91
Mackhack's Avatar
Booyah to ya!
Old 04-14-2011, 01:55 PM
  #92
conspawn's Avatar
audi
Some side notes about install, just to save the next person some time....
1. I put the bulky hardwire part with the main/accessory inputs, in the back of the piece under the shifter...there is much more room there then under the ashtray area...
2. To snake the phone wire from under the dash to the under the ashtray area, i took a metal hanger, bent it into a straight line, and went from under into the ashtray area, once it pops out in the ashtray area, make a hook and snake the phone wire back down.
Pretty happy with the install!!
Old 04-14-2011, 02:08 PM
  #93
Mackhack's Avatar
Picture that shows where your V1 is and where the cable is routed would be appreciated.
Old 07-05-2011, 01:36 AM
  #94
Ben Z.'s Avatar
E46 M3
Hey guys, first post here, I was able to install my V1 successfully in my 2007 E63, but I'm finding it almost impossible to tuck the wire under the headliner.. there doesn't seem to be any room? In my old E46 M3 you could pull the headliner down slightly to fit the cable; in the E63, the headliner seems sealed tight against the windshield.
Any tips? I have the wire hidden behind the secondary sun visor right now... it works, and is hard to notice, but is GHETTO!
Old 07-05-2011, 02:31 AM
  #95
Mackhack's Avatar
I'm making some adapters for those who are interested in using the overhead control panel for the power. It's like plug n play with them
Old 09-18-2011, 03:50 PM
  #96
irondad's Avatar
W205, X253, C190, W213,
I'm interested. Have you made them?
Old 09-18-2011, 03:54 PM
  #97
Mackhack's Avatar
I made a few prototypes for test purposes. They all work so far.
Old 09-18-2011, 03:56 PM
  #98
irondad's Avatar
Do they work just on the V1 or Escort as well?
Will you be selling them?
Old 09-18-2011, 03:59 PM
  #99
Mackhack's Avatar
I will be selling them soon. If you give me a detailed picture of the Escort power cable I can modify it for you...
Old 09-18-2011, 04:02 PM
  #100
irondad's Avatar
OK... it looks like a phone plug.
Quick Reply: V1 install
