Problems With MY W211 Radio
HELLO
i have a problem with mi 2003 w211 radio . it does it very rarely but it just drives me nuts...
sometimes when i turn the radio on the radio starts to ma a screeching noise that starts to increase in volume and at the same time you can see the computer display a COMMUNICATION MALFUNCTION on the dash display and after a few secconds the sound stops and then you can hear what ever music comes on the radio.. no matter what radio station it is on ,... if you turn the volume up while the problem is on hand the screeching sound increases and if you turn it down it does so to but the problem doesnt go away until it stops bi itself...
i have taken it to mi MB dealer and explained the problem but they have never seen or hear the problem .. so there is no way to fix it...
PLEASE HELP
johnys1st@hotmail.com
http://www.jg-enterprises.com
PLEASE HELP
2011 E550, 2013 GLK
Are you located in the US?
Has your dealer eliminated these as possible causes?
Component Description:
7. ELECTRICAL SYSTEM
Bulletin Number: 2005060008
Bulletin Date: AUG 2005
Vehicle: 2003 Mercedes-Benz E-Class
Summary:
IMPLAUSIBLE OR ILLOGICAL MESSAGES CAN APPEAR IN THE INSTRUMENT CLUSTER. ( NHTSA ITEM NUMBER - 10016646 )
9. ELECTRICAL SYSTEM:ALTERNATOR/GENERATOR/REGULATOR
Bulletin Number: 2005070017
Summary:
THE ALTERNATOR REGULATOR MAY FAIL TO PREVENT VOLTAGE VALUES RANGING BEYOND THE SPECIFIED TOLERANCE LIMITS. *TT
14. ELECTRICAL SYSTEM
Bulletin Number: 2004070019
Bulletin Date: OCT 2004
Summary:
FLASH CENTRAL GATEWAY (CGW). *TT
16. ELECTRICAL SYSTEM
Bulletin Number: 5410117
Summary:
CONSUMER SHUTOFF DISPLAYED IN INSTRUMENT CLUSTER WHILE DRIVING. *TT
Summary:
Summary:
Summary:
Summary:
Received 4,446 Likes
'71 Pinto
hello 1st of all thanks to all
I'm located in PUERTO RICO and to be honest here MB the service here really sucks they never find the problems and there's allot of red tape . i had a E430 with 16,000 miles and they had it almoust every week on the shop with a diferent problem and they changed avery part of that car and finally the decided to buy it back from me and ofered me my 2003 w211
About theese responses i will copy them to mi notepad and take them to my MB dealer the next time the car needs a service wich is around the corner.
My 2003 w211 has been a pain they even changed the transmision when it was brand new ,,,, and now when i turn the weel it sounds aufull no matter in what direction i turn the weel and it never stops .. this will be the new thing..
MY LEXUS IS 300 HAS NEVER GIVEN ME ANY PROBLEMS AT ALL AND THE SERVICE ADVISORS ARA IMPECABLE....
'71 Pinto
1) P-B-46.20/10/10a AUG05 Leak at Steering Rack Connection – Replaces O-Ring.
2) P-B-46.30/22a APR05 Noises From The Area of Power Steering Pump – Check for leaks, adjust power steering hose, and replace power steering pump.
3) P-B-46.20/16a APR05 Leaks at the Internal Steering Lines of the Control Head Connection and/or Steering Gear Housing – Replace all seals to control head and steering gear housing, if required replace power steering rack.
08' S550,,,C63!
08' S550,,,C63!
HELLO
PLEASE HELP
PLEASE HELP
