E-Class (W211) 2003-2009
Should I change my Transmission fluid
Old 08-21-2014, 09:42 PM
dewana421's Avatar
E320 2004 model Silver sedan
I bought my car (2004 e320) used with about 46k miles in 2007 and now I have about 120k miles on it. The only thing I ever did to the car was to change engine oil 0w40 every 10k. I haven't change the transmission oil ever and not sure if the previous owner ever did it.
My question is should I mess with changing the transmission oil when the car is running fine?
I searched but couldn't find anything on how to change the transmission oil with step by step instructions.
Can some one help please?
Old 08-22-2014, 06:14 AM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
IIRC, you can run 20K between oil changes. Not saying you should, but I believe the interval changed.
I would flush it. It is really easy. Find Shell ATF134 and get a good transmission flush kit. I ordered from ECS Tuning. It comes with a plug crush washer, gasket and filter.
Do a search for w211 transmissions flush - there are videos.
Basically drain the fluid, pull the pan. Clean it. Replace plug with new washer, and gasket, reinstall. BEFORE adding fluid - change the connector - it is most likely leaking. Fill with 4 quarts fluid.
Then disconnect the trans cooler line, and have someone start the car. Drain a few quarts and add a few. Drain, add, drain, add. Run it on the road and get the transmission up to 80C and test the level.
Old 08-22-2014, 07:29 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Do yourself and others a big favor---do not change a thing---if it aint broke don't fix it--you transmission is not a toilet ----don't flush it!!
Old 08-22-2014, 08:35 AM
Normally I agree with your comments/advice - but not in this case. The engine is still running as well, so he shouldn't change oil either? I disagree and stand by my suggestion.
Old 08-22-2014, 08:53 AM
Quadcammer's Avatar
96 and 08 911 turbos
I would avoid a traditional flush in the sense that some high pressure machine is hooked up to tranny lines and they blast away.
A flush in the sense of adding fluid, running the car with a cooler line running to a waste container for a few seconds, and then refilling (repeatedly) doesn't introduce any high levels of pressure or damaging fluids. It simply removes all the dirty fluid.
Its a risk either way really. The tranny could break tomorrow, new fluid or not. That said, I'd probably do it.
Old 08-22-2014, 08:56 AM
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
Change the ATF.
Do not power flush.
If you are worried change it twice.
Old 08-22-2014, 01:23 PM
vettdvr's Avatar
03 E500 and Corvette
Originally Posted by N_Jay
Change the ATF.
Do not power flush.
x 2
Old 08-22-2014, 03:48 PM
JoeNobody's Avatar
Mercedes
Change the fluid, filter, and clean the transmission pan off. Then after a few miles pump out the tranny fluid using an extractor and refill (I have this one and it works great:
Amazon.com: Hydro-Turf Oil Extractor 6-Liter OIL01: Automotive Amazon.com: Hydro-Turf Oil Extractor 6-Liter OIL01: Automotive
Make sure the fluid is the correct level too, and for that you'll need a special transmission dipstick.
Old 08-26-2014, 11:52 PM
dewana421's Avatar
what type of transmission fluid i should use on my base model 2004 E320?
Old 08-27-2014, 12:12 AM
Super Moderator
samaritrey's Avatar
THE C350
If it has the 5 speed 722.6 use Shell 134 ATF call up a local shell oil supplier and it should be less than $65 for a case of 12 quarts.
Old 08-30-2014, 10:39 AM
dewana421's Avatar
how do i know what type of transmission i got? 722.?? all i know its a w211 2004 e320. i did try to search but no sucesss. anyone can help me identify the transmission?
also should i use mercedes brand transmission oil or shell? as i will just be changing it from the bottom pan it will not remove all the oil I'm sure so if i use shell it will mix with mercedes brand oil which is currently in my car.
Old 08-30-2014, 03:47 PM
konigstiger's Avatar
Received 4,417 Likes on 3,146 Posts
'71 Pinto
722.6 "if it were me" in this situation I would use same ATF http://www.google.com/url?sa=t&rct=j...,d.b2U&cad=rja
Old 08-30-2014, 05:59 PM
dewana421's Avatar
so i can use Mobil ATF 134?
Old 08-30-2014, 07:09 PM
Plutoe's Avatar
1999 E300TD
You are confusing everyone---first you say you think it is MB fluid that is in the car---now you are referencing Mobil ATF 134--poster 12 suggests utilizing the same as whats in the car---so WTF is in the car and then use the same---how difficult is that---unless you havent got the foggiest idea what is in the car--that being the case use any MB speced fluid and get on with your life
Old 08-30-2014, 07:29 PM
2004 E320 has a 722.6 transmission. Use Shell ATF 134. But a case and do a normal flush. Make sure you change your filter as well.
Old 08-31-2014, 03:06 AM
MPOW33R's Avatar
(For Sale 03 G55), 08 G55K, 99 C43, 04 E55, 05 E63, 91 BMW E30, 05 BMW M3, 05 Audi USP Avant
Multiple AMG Certified techs have told and advised me
" IF YOU HAVE NEVER CHANGED YOUR ATF , DO NOT CHANGE YOUR ATF"
I have 185,000 miles on the ORIGINAL ATF !!!
Purrs like kitten. Shifts like butter.
Old 08-31-2014, 08:37 AM
Depends on the car. I have an ML that has 225K on it and no issues whatsoever.
On the E class 150K...I had issues and needed to change it.
Old 08-31-2014, 11:03 AM
N_Jay's Avatar
Old Wives (Mechanics) tale.
Lots of discussion here:
https://mbworld.org/forums/e-class-w...n-service.html
Old 08-31-2014, 11:05 AM
N_Jay's Avatar
Once the "issues" start, so have the problems.
Hence the reconfirmation of the idea the change caused the problem.
People drive till they notice the start of a failing transmission, THEN change the fluid and when it fails they blame the change.
Old 08-31-2014, 05:37 PM
Pretty much.
Old 09-01-2014, 12:36 AM
N_Jay's Avatar
Pretty much.
Some myths die long hard painful deaths.
Old 09-02-2014, 03:18 AM
Ragy.abuamra's Avatar
W211 E500 05'
ROFL
Funniest reply I ever saw
Old 09-05-2014, 03:51 PM
ron5668's Avatar
E350 4matic
2007 E350 4matic 141k original tranny fluid
Boardboysaid: "I would flush it. It is really easy. Find Shell ATF134 and get a good transmission flush kit. I ordered from ECS Tuning. It comes with a plug crush washer, gasket and filter.
Then disconnect the trans cooler line, and have someone start the car. Drain a few quarts and add a few. Drain, add, drain, add. Run it on the road and get the transmission up to 80C and test the level."
Boardboy, I just joined, I hope I am following the correct procedure. I cannot find a shop to do the process you describe above, can't even find anyone to drop the pan. They all want to powerflush or they suggest I don't mess with it. Any recommendations? I am near Laurel, MD. Also, can I use Shell ATF134? Thanks, Ron
Last edited by ron5668; 09-05-2014 at 03:58 PM. Reason: I used the quote system wrong, I think...new member.
Old 09-05-2014, 05:18 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
+1000
anything and everything will break...eventually.
its not a matter of how, but a matter of when. if you look after it, you will prolong its life.
Old 09-06-2014, 08:47 AM
JoeNobody's Avatar
Mercedes
Mercedes said the 7 speed should never have its fluid changed...then they later changed their stance and now say you should change the fluid.
5 speed is the same. If your trans fluid is cooked or full of metal bits, it cannot work and your trans is slowly tearing itself apart from the friction.
My transmission was misbehaving a lot, and after changing fluid twice and carefully filling using Mercedes trans dipstick, it's now driving excellent again.
Be sure you order the special trans dipstick!! Otherwise you are guessing how much fluid to pour in, and this alone is dangerous to the transmissions health.
Quick Reply: Should I change my Transmission fluid
