E-Class (W211) 2003-2009
Driveshafte bearing has cracks in the rubber"with video"
Old 04-28-2015, 11:15 AM
larsianer's Avatar
w211
this must be the reason cause my car vibrates,but are there any alligment dots,when i remove it??,and how do i remove the bearing with the rubber housing??
here is a picture of my flex disc, it has cracks, so i will use the new one i got.
Attached Thumbnails Driveshafte bearing has cracks in the rubber"with video"-hardyskive.jpg
Old 04-28-2015, 03:26 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
Driveshaft bearing - YouTube
MAKE SURE THE LETTERS AND NUMBERS ON YOUR FLEX DISC FACE THE REAR OF THE VEHICLE!!!!!
Old 04-28-2015, 03:48 PM
larsianer's Avatar
w211
Thank you, i will do that, are there any way to allign the center bearing drivshaft support"beam",cause i forgot the mark where it was??
or are there any way i can measure it?
Lars
Old 04-28-2015, 04:29 PM
cmriv's Avatar
Lars
There is a special tool used to install the new bearing, drifts and insertion/extraction tool... however if you don't have access to that tool see if you can find something to fit perfectly into the seal (large 1" socket probably in the 35-50 mm range) i'm not sure. and use a hammer or dead blow and tap it on slowly. If you didn't mark ANYTHING you could be taking everything apart again because by not aligning it the way it was, will cause horrible drive-train vibrations, maybe but you wont know until everythings back together. I can't give you any input on how far it should go on... use your pictures and videos... Someone else may be able to chime in on this as i usually mark things before I take them off. Sorry bud.
Old 04-28-2015, 04:36 PM
larsianer's Avatar
w211
Thanks for answer, i have not separated, the drive shaft, i know i need to mark it, i forgot to mark where the beam was,and i can move it a little in the mount holes, see the picture.part nr:60.again sorry for my bad english, i will try to get better
Lars
Attached Thumbnails Driveshafte bearing has cracks in the rubber"with video"-mellomaksling-bru.png
Old 04-29-2015, 08:57 AM
cmriv's Avatar
Lars
It's all good bro. Just take your time and don't hog up your new bearing. Since you do not have the proper to tools to seat the new bearing, be extremely careful and precise. Good luck!
Old 04-29-2015, 08:43 PM
vaccin's Avatar
05 cdi 3.2 92 300d 2.5
A procedure would be great is someone has the wis
What year is your car?
Old 04-29-2015, 10:33 PM
cmriv's Avatar
I have a 09. post your vin.
Old 04-30-2015, 03:10 AM
larsianer's Avatar
w211
can it be this nr:WDB2112081B281033
Old 04-30-2015, 04:22 AM
wjcandee's Avatar
2004 Mercedes E500, 2008 Mercedes ML350
The guy at MercedesSource has a good video on the driveshaft. It is balanced at the factory, so it has to be put back exactly as it was when you took it apart. He uses a simple piece of masking tape along it, which you then tear before you pull the shaft apart. Then you just line the tape up again when sliding it back together.
Old 04-30-2015, 10:20 AM
larsianer's Avatar
w211
now i have taken the driveshaft of the car, and i have marked it everywhere..hehe..
The new center bearing will be here in the end of next week,i live in Northern Norway, so everything goes very slow
Attached Thumbnails Driveshafte bearing has cracks in the rubber"with video"-driveshaft.jpg
Old 04-30-2015, 10:29 AM
larsianer's Avatar
w211
But the question is, how do i allign this part?, cause the two holes are long and square,and can be mounted wrong if i dont get it straight/as it was??
Attached Thumbnails Driveshafte bearing has cracks in the rubber"with video"-lager-holder.jpg
Old 04-30-2015, 03:27 PM
vaccin's Avatar
The splined yoke is also mated to each other for balance
If you have a dial gauge you can check run out as your adjusting to the center.
The run out is 0 degrees
Google driveshaft alignment with Guido or rubber flex disks.
Quick Reply: Driveshafte bearing has cracks in the rubber"with video"
