Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W212)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
E-Class (W212) 2010-present: E 350, E 550
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 03-03-2011, 04:04 PM   #26
Drives: 2010 - E350 Sport
Send a message via AIM to MatOhio
Bulletin LI32.25-P-051123 FEB11
Is this a new Bulletin? My E350 has been at dealer since Tuesday AM - noise as described in the Bulletin plus an ongoing vibration (buzzing) issue in Steering Wheel. Called today to see what was going on, since I had not heard anything since dropping it off, and was advised he is waiting on parts - front strut(s). Asked why and was told, "...you heard a noise, so the tech thought we should do this." Not sure if doing just one or both - should they be done as a pair? If say they are just doing one, should I request the other one be done as well? Interesting timing; I just wish they could be up front about what is going on - I am happier knowing the truth and reason for an action, even if it isn't what one would hope for.
Also replacing a defective rear shock absorber PLUS just had a defective front shock replaced in February!!!
Is my vehicle a Zitrone?
To remove this ad, register today or login if you already are registered!
MatOhio is offline   Reply With Quote
Old 03-03-2011, 04:10 PM   #27
konigstiger's Avatar
Drives: '71 Pinto
Quote:
Released 2/14/11
__________________
konigstiger is offline   Reply With Quote
Old 03-03-2011, 04:14 PM   #28
Replacing Front Struts
You are a wealth of valuable information adn all that visit this forum surely appreciate your knowledge and insight.
In the case of this bulletin, should both struts be replaced or is replacing one acceptable?
Old 03-03-2011, 04:26 PM   #29
Drives: '71 Pinto
Both, check PM
__________________
Old 03-08-2011, 10:32 AM   #30
Are there any details/specifics available on what the changes/modifications are on the new units?
Old 03-08-2011, 10:59 AM   #31
Drives: '71 Pinto
Internal damping module of strut was modified, see “Cause” in bulletin copy I sent.
__________________
Old 03-09-2011, 10:22 AM   #32
Thanks. LAST question (I hope): Should the vehicle have an alignment after the struts are replaced? Does replacement impact the alignment settings?
Old 03-09-2011, 12:42 PM   #33
Drives: '71 Pinto
No, the only additional step would be to check headlamp adjustment.
__________________
Old 04-04-2011, 03:45 PM   #34
Drives: '71 Pinto
LI80.61-P-049924 MAR11 – 204/207/212 Keyless-Go “key not recognized” unable to start engine, update KG control unit software.
LI54.30-P-050163 MAR11 – 207 without memory package (275), backrest not locked continues to be displayed after locked correctly, update IC software.
LI82.70-P-051455 MAR11 – 212 called party has difficulty understanding driver; voice inputs via VCS are misunderstood, update COMAND software.
LI91.10-P-049894 APR11 – 204/207/212 noise or play at seat adjuster, shim will be fitted.
__________________
Old 04-19-2011, 03:50 PM   #35
Drives: 2012 S350 Bluetec 4Matic, Diamond White, P2
Quote:
Would it be possible to see the entire description of this issue?
ImInPA is offline   Reply With Quote
Old 04-19-2011, 07:10 PM   #36
Drives: '71 Pinto
Quote:
Certainly, PM email address and I will send bulletin.
__________________
Old 05-02-2011, 05:20 PM   #37
Drives: '71 Pinto
LI80.57-P-051521 – 207 no crank/start/intermittent no crank, if EIS is part # 2045455732 replace with 2045458132.
LI91.25-P-051700 – 212 as of VIN A344516 up to A387562 multicontour seat inoperative replace backrest padding (massage unit and actuator are permanently installed in padding).
LI91.25-P-051599 – 212 dynamic seat function or multicontour system inoperative replace air cushion on front seat backrest with improved part.
__________________
Old 06-02-2011, 01:34 AM   #38
K-A
K-A's Avatar
Drives: '13 BMW 535i M Sport / Ex M-B's: '11 & '10 & '06 E350's, '02 S500
[B]
Hey Konigstiger, I used this DTB hoping it would give me the new Command upgrade that some here have gotten (with the Bluetooth streaming, fixed POI's-where it doesn't give you a random City location, better graphics, A/C display on the bottom of the screen, Nav Map graphics upgrade, etc.), and after them saying that they were uploading new software for 2 hours (which I know they did, because apparently it crashed right before it was complete the first time, and I had to leave the car overnight), I see absolutely no changes to my Command. Did I give them the wrong code for what I seeked?
__________________
'13 F10 BMW 535i ///M Sport : Jet Black/Black-Anthracite : Premium & Technology Packages/Sport Auto Trans/Camera/Park Distance Control/Heated Seats/Tinted Windows/Blacked Out Markers/Performance Spoiler.
Ex M-B's: '11/'10/'06 E350's w/ AMG Sport Package, '02 S500 w/ Every Option.
K-A is offline   Reply With Quote
Old 06-02-2011, 06:39 PM   #39
Drives: '71 Pinto
Service Campaign 2011030004 MAY11 – MY11 212 dealer will check vibration damper and replace if necessary. If the first 3 digits on barcode are 167, replacement is necessary. Approximately 41 vehicles are affected.
LI72.12-P-051929 MAY11 – 212 wagon up to VIN A406843; cannot open rear door in low outside temperature, strip on the inner sealing lip can become drenched and then freeze onto roof frame, dealer should install modified left & right window guide rails.
__________________
Old 07-07-2011, 04:20 PM   #40
Drives: '71 Pinto
LI32.22-P-052062 – 212 thumping from area of the front axle when driving over speed humps when the suspension strut rebounds, the rebound buffer spring causes a metallic knocking noise. Dealer should flash Airmatic control unit.
LI54.21-P-052072 – vehicles with 276/278 engines CEL in IC but engine does not display any problems (i.e.: fault code P060600) update ECU.
__________________
Old 08-08-2011, 04:18 PM   #41
Drives: '71 Pinto
LI42.47-P-052197 - e63 VIN A415231-A421136 when attempting to switch on the Attention Assist function fault message appears, perform SCN coding of ESP control unit.
__________________
Old 10-17-2011, 01:48 PM   #42
Drives: '71 Pinto
LI91.25-P-052529 SEPT11 dynamic seat inoperative shortly after restart flash multicontour seat control unit with new software.
LI03.10-P-052286 SEPT11 knocking noise from engine, inspect cylinder walls for scoring if found engine must be replaced. Affected vehicles are mostly production dates from 8/10 to 11/10 but might be outside this range situation was corrected as of engine # 2729xx 31932895 & 2739xx 30441186.
LI27.60-P-049981 OCT11 hard shifts, poor start characteristics, uncomfortable jolting – check oil level, check for software releases and check engine for unmetered air.
__________________
Old 10-17-2011, 03:36 PM   #43
Drives: 2010 E350 Luxury Sedan
Engine Numbers
Where are the engine numbers located?
El Cid is offline   Reply With Quote
Old 10-23-2011, 09:35 AM   #44
listerone's Avatar
Drives: 2011 E350 Bluetec
Quote:
Don't know where they're located *on the vehicle* but you can get it from the "datacard" available at startekinfo.You can sign up for free (for the first year IIRC) and once signed up you can get all sorts of interesting,useful,info about *your* vehicle (including your engine number) by entering your VIN number.
__________________
Currently:2011 E350 Bluetec / Palladium Silver / P1 / Distronic / Parktronic
Formerly :2009 BMW 335 diesel / Nav /iDrive / Sirius / HD radio
listerone is offline   Reply With Quote
Old 11-15-2011, 04:29 PM   #45
Drives: '71 Pinto
Service Campaign 2011100004 NOV11 – 2011 w212 Central Gateway (CGW) may not meet specifications dealer will update software. Approximately 2,575 vehicles affected have dealer check VMI to see if VIN is included.
__________________
Old 11-26-2011, 03:07 PM   #46
Please take a listen and tell me your thoughts; YouTube link to my engine noise. One dealer told me normal but I beg to differ. Thanks. http://m.youtube.com/index?desktop_u...?v=6dkxZhr84ks
Old 11-26-2011, 05:17 PM   #47
Drives: '71 Pinto
Check your email.
__________________
Old 12-13-2011, 03:52 PM   #48
Drives: '71 Pinto
Recall 2011110002 – MY11 212 diesel fuel filter may develop leaks approximately 6,784 vehicles affected. Owners should receive a letter or have dealer check VMI to check if VIN is included.
LI46.20-P-049852 – 207 all, 212 except 4matic honking/squeaking noise when steering in both directions mainly occurs when warm. Radial shaft sealing ring to steering system will be replaced.
LI83.00-P-051420 – 212 up to VIN 1A411562 & 218 up to 1A004916 whistling or humming noise. If the noise disappears when opening a window, the problem is caused by the drain grommets of the sliding roof hose @ left & right rear.
__________________
Old 01-10-2012, 02:00 PM   #49
Drives: '71 Pinto
LI88.20-P-052891 - 212 rear bumper sticks out in area of rear lamp. Bumper experiences thermal expansion mounting rails (fender area) cannot sufficiently hold the bumper in place. If bumper is not equipped with additional latch, it should be replaced. Note since JAN11 bumpers are equipped with additional retaining tab.
__________________
Old 01-11-2012, 12:33 AM   #50
Drives: 2008 Mercedes Benz S550, 2011 E350, 2013 SLK350
Oh crap! I have a 2011 E350 and on one side, the bumper protrudes (it has protruded since day 1 I bought the car). My car has a build date of 7/11. Does this mean it doesn't fall under this bulletin?
__________________
Vehicles I Drive:
1) 2008 S550 - Capri Blue/Cashmere - Package 3, Premium Leather, Distronic PLUS, Rear Seat Package, AMG Sport Package, Wood/Leather Wheel, Rear Side Window Blinds, Panorama Roof, Active Body Control
2) 2011 E350 Sport - Black/Almond w/Burl Walnut Trim - Premium 1 and Panorama Roof
3) 2013 SLK350 - Black/Black - Black Ash Wood, Sport Package, Multimedia Package, Lighting Package, Pano Roof, Rear Spoiler, Chrome Hood Fins, Keyless-Go
amaycg is offline   Reply With Quote
Tags
08, 2009070001, 2010030007, bulletins, campaign, e350, jul09, li6810p047474, li6820p047911, lubricating, mercedes, sept09, service, struts, w212
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
