Lowered Springs for 2014 models
2014 E250 CGI
Hey guys,
I am planning to lower my 2014 E250 with some H&R springs, and i have a few questions for the experts here!
1)Does the new facelift W212 model share the same chasis and suspension setup as the previous W212 model?
2)Currently no springs in the market designed specifically for the E250, but they do for the E350 and E550. The E250 is RWD and doesn't have adjustable height suspension. So I am assuming that it shares the same setup as the E350 and E550?
I am also curious on what a 1.3-1.5 inch drop would look like. It would be great if the veterans here can share a few pictures of their lowered W212.
thanks,
Jeff
thanks,
Jeff
hi ive just purchased a 2014 e250 sport and have found that the suspension set up to be different I purchased a set of 19" wheels 8.5j and 9.5j and was told that a offset of 35 would work but they didn't in the end I went for a 45 and the rears are on there limit if anything they stick out a bit to much but the fronts are perfect,
yesterday I had a set of h&r springs fitted which I was told by both h&r and eibach would be the same on all face lift as the earlier w212 but again they are not they did fit but the front has dropped about 40mm and the rear has no difference I know they may need time to settle down but I think the front is way to low already hope this can be of some help.
