Car puts itself in Park while coming to a stop
Old 11-16-2014, 08:26 AM
swwags's Avatar
2010 E350
2010 E350 P01 Premium Package, 321 Sport Package.
1st let me start by saying I did not open the door while the car was moving. All doors were checked and rechecked to be closed and locked.
Driving from Minnesota to Iowa. About 23 degrees f. Approximately 150 miles into the trip we stopped for a bio break. As I was coming to a stop at the bottom of the exit ramp, the car put itself in park and we skidded a few feet.
This happened under 5 mph. It continued to happen as we drove to the gas station, at each stop and then returning to the freeway.
Before returning home, we attended an event for a couple of hours. (so the car cooled down) Getting back into the car, we drove around town in IOWA and had no issues, coasting to several stops and then braking normally.
On the commute back to Minneapolis, we stopped again for a bio break after about 3 hours of driving. Again, when coming to a stop, once the car dropped below 5 mph, the car put itself in Park.
I searched the forums and have found this happening when people had the car in drive and opened the door. We tested that out in Iowa before returning. The "door open" warning light came on so I'm thinking that I've eliminated the possibility that the car thinks the drivers door is open because no such light comes on with my problem.
I put my scanner to the car this morning and no codes of any kind.
My wife's car so she will be calling the dealership on Monday but I'm hoping the collective intelligence of this group can point me to something.
FYI, the car has been owned by us since June, only driven locally until this weekend's road trip. Never had the issue previously.
CaliBenzDriver (08-16-2022)
Old 11-16-2014, 09:36 AM
BeachBunny's Avatar
2018 E300 Luxury - P3 and more
Just a suspicion, but I'm wondering if the Auxiliary battery (or main battery) is getting a little on the weak side. I'd imagine if voltage drops, the system might drop into Park. Just shooting from the hip on this.
CaliBenzDriver (02-11-2020)
Old 11-16-2014, 04:40 PM
swwags's Avatar
2010 E350
Thank you for the reply and suggestion BeachBunny. I would have expected an error code but also would have expected it to happen regardless of a road trip. Of course there is the possibility that the road trip was just the beginning:-)
I'm unable to find a way to effectively "test" the battery but could certainly replace it, unless someone can recommend an effective load test how to?
Or possibly point me to the service document/ wiring diagrams for this battery?
Old 11-17-2014, 12:32 PM
BeachBunny's Avatar
I'm not sure where you're located, but many of the auto parts shops around here (Discount Auto Parts, Pep Boys, etc.) will test batteries for free.
On your car, the auxiliary battery is located underneath the driver's side dash and looks like an alarm system battery.
Batteries Plus or similar store might be able to handle it as well.
Old 11-17-2014, 01:07 PM
konigstiger's Avatar
Received 4,417 Likes on 3,146 Posts
'71 Pinto
If battery part 4040 is found dealer should replace it with 4039 at no cost due to poor/loose fit with terminal connector (reference C1A 100301) in addition, have dealer check Vehicle Master Inquiry (VMI) to confirm there are no outstanding service campaigns.
Access shown here http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
Old 11-17-2014, 09:04 PM
swwags's Avatar
2010 E350
[QUOTE=konigstiger;6233342]If battery part 4040 is found dealer should replace it with 4039 at no cost due to poor/loose fit with terminal connector (reference C1A 100301) in addition, have dealer check Vehicle Master Inquiry (VMI) to confirm there are no outstanding service campaigns.
Thank you again. I did verify my car has gone through (serviced) 4 campaigns, but not this one. However, the SAM was serviced so I would guess the battery was inspected. I will check the battery and likely just replace it as they are cheap insurance. I'll wait until the weekend when hopefully the temp gets above freezing and will report back.
FYI, I've also been corresponding with another gent who experienced the same problem. Stumped the dealership and they ultimately replaced his EIS which he indicates solved his problem. I've yet to pull down the schematics and see how the backup battery ties to everything. Perhaps I can get that done this weekend if it's too cold to inspect the car.
Also, I drove the car around town today and was unable to replicate the problem so I've got that going for me:-)
Old 11-18-2014, 11:04 AM
mjvickers's Avatar
e350 w212
e350 automatically shifting going into park w212
Hey, Here is my thread on this issue on
I got the car fixed at the dealer.
http://www.benzworld.org/forums/w212...o-park-no.html
Old 11-18-2014, 11:58 AM
'71 Pinto
Bulletin LI54.25-P-056472 “The key is not recognized in the electronic ignition switch, the vehicle cannot be started and/or the automatic transmission may perform an "Automatic P function" at speeds below 6 km/h.”, replace electronic ignition switch due to assembly issue - 212 clean point (problem corrected) as of VIN A776831.
Repair is covered under warranty, if out of warranty and below VIN A776831 bulletin will assist in obtaining MB goodwill assistance.
DeutscheBenz726 (08-23-2020)
Old 11-18-2014, 02:33 PM
BeachBunny's Avatar
If Mercedes gives you any grief about paying for it, file a complaint with NHTSA. NHTSA was very helpful with the issues I had with Infiniti. The process is slow but I'm responsible for 3 of the recalls on my car.
The following 2 users liked this post by BeachBunny:
Aussie_E350_Wag (01-28-2023), CaliBenzDriver (08-16-2022)
Old 11-24-2014, 09:28 AM
swwags's Avatar
2010 E350
A quick update. Took the car to the dealership Friday and they found the problem to be with the EIC and the ignition is on order. We have a loaner until the part comes in and is replaced today or tomorrow.
Old 11-24-2014, 09:50 AM
noka's Avatar
'15 E350 4M Sport
That had to be really annoying. Good to hear it will be fixed!
Old 11-25-2014, 02:00 AM
2nice4me's Avatar
2011 E350 4 Matic
Is the dealer doing this Free of charge?
Old 11-25-2014, 09:30 AM
swwags's Avatar
2010 E350
They are covering it under the CPO Warranty
Old 04-13-2015, 03:42 PM
whaddaiknow's Avatar
2010 Mercedes-Benz E350
Ignition Switch blues
I know I am reviving an old thread. But since this is my first post here, I thought someone could find it helpful.
I had the exact same issue with my 2010 E350 that I purchased at the end of November 2014. It WAS fixed by replacing the EIS (under CPO warranty) but the experience of car suddenly coming to a stop at an intersection showing the broad side to the oncoming traffic with my 3 kids in the back was scary.
I am in Ontario, Canada.
BTW, love the forum. Loads of useful information.
pierrejoliat (01-16-2021)
Old 08-10-2017, 08:38 PM
ratthing's Avatar
2012 E350 Sedan (Base model)
I just experienced this very issue with my 2012 E350 sedan. As I was slowing to a stop at a stop light, it just shifted into "P" right before I came to a complete stop.
Based on this thread, it looks like my best bet is to visit the dealer. Aside from telling them what happened and mentioning the EIS , is there anything else I should tell them to make sure this gets fixed right?
Thanks!
Old 08-11-2017, 03:19 PM
'71 Pinto
Present attached bulletin.
File Type: pdf
The following 2 users liked this post by konigstiger:
pamiboy (11-15-2019), ratthing (08-11-2017)
Old 08-28-2017, 01:12 PM
ratthing's Avatar
Just wanted to give another thank you to konigstiger and everyone else here.
The dealership just called and said they definitely need to replace the ignition switch and will do so. I think having the bulletin really helped to speed things up.
Old 04-20-2018, 12:33 PM
GLKFever's Avatar
GLK 250
Thumbs up GLK250 - Car goes into Park by itself
2015 GLK250
UPDATE 2018 - Key in electronic ignition switch (EZS) is not recognized, automatic transmission shifts to Park before vehicle comes to a stop.
Refer to Service Bulletin L154.25-P-056472_Ver_3
Complaint:
The key is not recognized in the electronic ignition switch, the vehicle cannot be started and/or the automatic transmission may go into Park at speeds below 6 km/h.
Cause:
An assembly issue in the electronic ignition switch (EZS) results in a transition resistance at the diodes of the key detector. The key is detected as "not inserted" and may go into Park.
Remedy:
Replace electronic ignition switch. Before replacing, perform the guided test of the drive authorization system!
It took the dealer 5 days to figure this out. Bring the Service Bulletin to them before you go in, so it doesn't take that long.
This website is a blessing!
Old 10-01-2019, 08:32 PM
vsangamalli's Avatar
E350 Blutech
Hello, I am facing identical issues with my E350. Car slips into park randomly at very slow speeds. Additionally engine makes noises before slipping into park. Anyone else face identically issues with engine noises.
Old 10-01-2019, 11:13 PM
ratthing's Avatar
The thing that fixed mine was replacing the ignition switch.
Old 10-02-2019, 08:03 AM
GLKFever's Avatar
GLK 250
Replacing the ignition switch repaired it from recurring; it was repaired under warranty after they replaced the Transmission neutral switch. Just emphasize that its the ignition switch.
Old 11-15-2019, 08:10 PM
randy0211's Avatar
E350
Does anyone have the latest part number on the warranty? Please help ASAP. I have someone who is can program the old one, but I don't want to put the same part to fail again. The current old part number is 2129055800
Old 11-17-2019, 10:20 AM
'71 Pinto
VIN?
Zorannn (12-13-2019)
Old 12-13-2019, 03:35 AM
Zorannn's Avatar
Mercedes E220 CDI W212
W212
VIN?
Hey konigstiger i have been reading your posts to MB sites and i need your help now, i am having a W212 2012 year of production and the car puts itself into park at speed of 5-10 km/h, and same thing when car is in reverse and neutral can you Help me?
Old 12-19-2019, 04:42 AM
Zorannn's Avatar
EIS
The problem is the ignition switch yesterday i have changed my eis and the problem has disappeared.Thanks to all of you guys for helping me and all of you who have the same problem go and change your EIS and the problem will be solved
Quick Reply: Car puts itself in Park while coming to a stop
