G 500 transfer case in neutral
Start the Gwagen, press the brake pedal down, place it in neutral, apply foot to brake pedal and hold there, hold down "Low" (bottom of Switch) side of Low / High Transfer case button.. for 15 - 20 seconds.. Transfer case will shift into Low range.. You will feel a Clunk below your feet.. release the button.. press the high side of the Button ( High Range ) and you are done.. vehicle is in high range and the transfer case module is reset! the beeping when you exit the truck, and the message " Transfer Case in Neutral " will be gone!
Land Rover Discovery Series II 2000, 2003 Mercedes G500, 2010 E350 coupe
I followed the instructions and it worked and beeping stopped so I proceeded to turn it off and it went back to lower with the H disappearing. I repeated the steps again and it stopped but I didnt proceed to take a brief mile up the road. Overall what you wrote does work. I dont see any comments from women on here about their G-Wagon (just a observation).
It appeared my Battery was the cause of the problem. Once I change my battery everything appeared normal. So there was no issue with transfer case giong in to L or H.
2013 G63
I thought that maybe the motor was the issue, i replaced that and nothing changed.
Any other insight?
