Rear tire wear
Old 12-16-2011, 02:24 PM
Shellbmb's Avatar
14 GL550; 14 E63s
Rear tire wear
Just replaced the rear tires and didn't realize how bad they had gotten. Is this normal uneven wear due to the camber, or is something off? These were the rear tires and the dealer has serviced it twice this year with the last service just 5 months ago where they replaced the fronts. These rear tires had about 30k miles on them.
Old 12-16-2011, 03:56 PM
alx
alx's Avatar
your camber is way off...
if aligned properly your gl should not wear tires unevenly.
Old 12-16-2011, 04:53 PM
JimBarnhart's Avatar
2015 Ram 2500, former 2013 GL350, 2007 GL450
I had this happen to one rear tire. I had a shock problem that caused the very fast and uneven wear compared to the others.
Old 12-18-2011, 02:15 AM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
Do you rotate your tires? I don't ask to be a smartass in any way, just thinking that any decent tire person would have seen such uneven wear and pointed it out.
Old 12-18-2011, 03:02 PM
43221B's Avatar
15 GL550
My 20" runflats are starting to get similar wear. They are nowhere near as bad as yours but I can see them looking like that in 3000-4000 miles. I have 34000 on them right now. All four of mine have excess wear on the inside shoulder. I have rotated every 5000 since new. I'm having mine replaced next week and I'll have them check the camber.
Old 12-20-2011, 10:36 PM
43221B's Avatar
15 GL550
FYI, dealership said that my wear is normal and that the alignment was within spec.
Quick Reply: Rear tire wear
