water leak
water leak
First of all, hello to everyone!
I am new in this forum. Cause my mother langue is not english please do not hesitate about words that i use.
Reason why i am asking help is water. Today suddenly some problems came up with my GL. First two error message that both breake lights wont work. and same time tailgate do not close( i do not have automatic tailgate that moves). Both of breaking lights were ok. Also fuel level changed in many times
I started to find out problem. First i checked the fuse box, which is back of the car. When i opened this box i saw there water. Not much but, there were some drops and some cables were wet. So i understood that water caused those problems that came up. Later i nthe day problems solved by themselves, but there is still wet near the fuse box.
I think water is leaking somwhere, but where? maybe someone of us have had similar problems?
My R Class had a leak and there was water at the bottom of the spare tire well. Turns out the leak was coming in from the passenger side vent that is behind the bumper. I needed to replace the vent with a new one and my problem was solved. I understand that my car, form the previous owner, had some sort of rear end damage. It's possible that this vent got compromised during the minor collision and perhaps your car has a similar issue?
Otherwise I have heard of water coming in through the third brake light at the top of your tail gate.
For now you should take off the rubber plug at the bottom of your spare tire area so the water can continually drain until you find the root of the problem.
its either coming in around the tail lights or around the seals on the panoramic third row sunroof.
check both points of entry and fix this ASAP - or you’ll have electrical issues for the remainder of this cars life, which may be very short.
