which 18" OEM MB wheels fit a 2012 GL350 (for winters)
I usually like to stick to OEM wheels, since they can usually be found cheap used, and their offset, etc is perfect.
Discount has a decent looking 18" winter package for the GL, but I wanted to see what OEM options are available.
I think older GL's had 18" wheels, and perhaps ML wheels fit?
Thanks!
Thanks!
OEM is the best (and not always cheap). I'm using 18s for my winter set. Check owners manual. In mine it says what rims are available and what tire size should be used. I'm pretty sure you can use 18s from GL320 on your GL350.
2008 GL 320 CDI Black/Black
I got a set of rims for winter and Blizzacks from tirerack.com. In fact my MB dealer steered me this way too! The rims came with tire sensors and have worked flawlessly on my GL going into their 4th winter! Even MB dealers will tell you their wheels are overpriced... I bought 18's as discussed above - as a general rule, smaller and slightly narrower tire is better in winter. Good luck.
2007 GL450, 2006 Porsche 911, 2004 VROD
Thanks!
Thanks!
http://www.allfactorywheels.com/prod...31088_zoom.jpg
